oscarc
- Jul 30, 2011
I do both. Mixamp is usually half way between 50/50 and all voice and the headset adapter is max voice.
My set up is slightly different from yours though, I have a fiio e17 between the mixamp and my headphones (currently using a modmic as well). But essentially you should have optical & usb going from mixamp -> xbox then boompro into mixamp and chat cable from mixamp to the headset adapter. Make sure the boompro is plugged all the way into your headphones as well.
I have a pair of X1s and a boompro coming tomorrow so I'll let you know how my experience goes with it.
Thanks. The USB just provides power, so theoretically it can plug into any port for power (TV, Cable box, etc.), right?
I plan to amp, but don't want to connect everything at once and get more confused setting it up. I have an O2 and FiiO E12 and not sure which one would be better.
I am assuming the Mixamp sits between the headphones and the amp. X1 -> BoomPro -> amp headphone jack, interconnect cable from amp -> Mixamp headphone jack. XBOX headset adapter via 2.5mm to 3.5mm cable to the controller part on Mixamp. Do I have it right?
