- Mar 20, 2010
Nope. But I don't like the the new CoD that tries to be like it either.
Thanx for the reply. Your review was the reason I bought the Recon3D
I thought the gun sounds were kinda loud because I've used this setup with my MA900,HD598,HE400,AD900x and the K612 was the only one with this problem
I just couldn't get a balance where I could hear the details and the soundstage without going deaf from the gun shots
I liked Destiny's double jump, sliding, and I generally like CoD:AW, but sometimes AW seems to go too far into tactical speed (and can be a bit of a complication to get the movement you want) and sometimes I go back and play CoD: Ghosts because there's a little more strategy and sound hunting without the exo move boosts. I'm tempted to go back and play some of my fav Xbox 360 games, but I don't have a Live subscription anymoreNope. But I don't like the the new CoD that tries to be like it either.
I play Visual Novels in DH. Would the X7 LE be beneficial?
Oh. Well, I'm sure you can understand that it feels gratifying to know that not only was work I put into the review actually read, but also at least a little helpful.
After using the HD700 for awhile, going back to the K612 felt like the mids (the meat of the sound) were recessed but some treble was emphasized. Interestingly, there's still plenty of uniqueness and benefit to the K612 not in the HD700, buuuut... I guess where I'd start is looking at K612 or K601 freq curve charts and reducing the treble frequencies a bit using the Recon3D. Just a little. Maybe try a little dynamic range compression, halo 4 for example has some REALLY loud volume spikes (hello warthog!), after waking up or when I'm tired sometimes I admit to turning the volume down a bit and using "scout mode," it's not reference but at lower volumes I found it easier on the ears if I was tired.
Good luck!
P.S, how was MA900 vs HD598?
Sure, just use the female vocals preset. On an indirectly related note, the headphone stand will nicely display other small affects too... I've got my hat hanging on it right now.
I recently purchased the V-MODA BoomPro Gaming mic to chat on my X1 headphones. I am using a MixAmp Pro 2013 as well. I thought I had everything connected properly but am having issues hearing voice as it sounds very faint with the voice dial all the way up (game audio then sounds echoed). I am also not sure if they can hear me. Should my name come up on the game when I speak like I see when others are talking? Here is my setup:
V-MODA BoomPro connector from the X1 into the headphone jack in the MixAmp. The BoomPro comes with a splitter (one for audio, one for voice). I am assuming I don't need this for the MixAmp. Am I right?
Cable that came with the Stereo Headset Adapter to the Astro 2.5mm - 3.5mm cable. The right angle end connected to controller port on the MixAmp.
I have Optical set to Bitstream Out and Bitstream format to Dolby Digital. I have also unchecked to use voice from the Kinect.
I am doing everything right or is there a step I am missing to get this working properly?
Hardline is bad, bf4 isn't bad i am just sick of playing it like everyone else..battlefront should be good though..p.s here's a new star wars arcade machine that's just been released, hopefully it's at pax east this year..
I had this problem too. The stereo headset adapter also works like the mixamp in a way. The buttons on the left work like the game/voice dial on the mixamp. I had to hit the voice button (bottom left) until I started hearing the max setting tone. You can then use the volume buttons to increase the sound (on the adapter). Do you have the usb of the mixamp going to the xbox as well?
Tbh i'm not a huge fan of this set up. Too many damn cables and then the issues w/ voice.
Dumb question, but have you turned the chat volume all the way up on the X1 controller?
