Except, receivers are notorious for adding huge amount of input lag and Yamaha was (and still is) some of the biggest culprits.
If you run your video to the TV directly and only run the audio to the AVR, you bypass that.
@FDDreamer, You're perfectly entitled to your opinion on Chinese vs Austrian AKG's. However, I have a Chinese Q701 and I've never had any issues with it. I haven't met anyone in the Q701 thread who believes there is any material difference between versions. They've been proven to sound identical as well.
What I'm trying to say is that there really isn't any logical grounds to worry about inferior quality when it comes to Chinese vs Austrian AKG's. If it bothers you anyways, by all means, get something else. But I wanted to make sure you're aware that there's not really any reason to worry about it.
Yeah, of the mindset that if I have zero gear, I'd go right for the X7 as that takesbcare of 3 things:
DAC
Amp
Virtual surround
That is how everyone should at least break the X7 as. Of course, its quite a bit more than that, as it can also drive some passive speakers, but in terms of headphone specific duties, you have 3 devices worth of stuff in one package that happens to do it for both PC and external consoles.
The only reason I wouldn't get it myself is because I already have these things. If I somehow sold everything, then yes, I'd buy one myself. I kinda really like my mostly untethered freedom with the Mixamp 5.8 though, so it'd be hard for me to give it up again.
Yeah, of the mindset that if I have zero gear, I'd go right for the X7 as that takes care of multiple things:
DAC
Amp
Virtual surround
Virtual surround PC device
That is how everyone should at least break the X7 as. If viewing it as just those things, its essentially like $400+ worth of those things if you were to buy single devices like a Modi, Magni, Mixamp, Xonar U3 or whatever Creative equivalent there was (for pc purposes). Of course, its quite a bit more than that, as it can also drive some passive speakers, but in terms of headphone specific duties, you have 4 devices worth of stuff in one package that happens to do it for both PC and external consoles.
Finally, thank you for the tip re. Austria / China. If the quality is there then I see no reason to be worried by where it is actually assembled! I guess I'm getting old and cynical and couldn't help but apply the 'if it's too good to be true...' adage to the K612 when it costs so little!
I had a Honda CBR600F4 motorcycle in 2002 that was the best 600 supersport you could buy. It was winning every shootout in every magazine and was THE bike to get. Not even ten years later, they were selling the EXACT same bike, but it was their "entry level" 600 sportbike. The newer bikes got so much better that the older tech was that outclassed by comparison. But that older bike didn't change. Everything that made it so amazing in 2002 was still there.
That's how I think of the K612. It's a entry-level version of the K7-- series that's really quite good on its own, and is only entry-level in direct comparison with its newer better brothers.
(Caveat: I haven't heard the K612. Take the comments above for what they're worth.)
I like your analogy!
As a complete newcomer to all this I am more than happy to look at an entry-level headphone. In fact, from the reviews I've read it may be that I'd actually prefer the K612 to the K7 series due to the slightly warmer sound and fuller bass. I've read the K612 can be a little picky as to the system that drives it, but I imagine the Sound Blaster Zx would be fine with it? I've also been digging around for any known issues with the K612 (specifically the cable as it's not removeable) but have turned up virtually nothing which is really encouraging!
Problems on the X2 also seem few and far between, although I did notice that their sound can deteriorate when using a high output impedence amp. Not sure if that would apply to me or not, but they would be driven by the SB Zx. Crikey there's so much to learn.
Any idea on what a comparison for gaming would look like between the K712 and 7XX? That's a big price difference, don't want to spend extra for almost the same product. Reviews are confusing, since they tend to not focus on the gaming side at all.
