Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
Hey! I'm looking for a new pair of headphones and need some help.* Should be around 200$* I listen to very much different like, Dubstep,RnB,mainstream pop, beatles ans so on.* It should have good detail for beatles and pink floyd, still want great good bass for pop and dubstep.* I'm only going to use it around my comp. so if its bulky, closed or open doesn't matter.* It's going to be connected to my receiver..
Get a Beyerdynamic DT880pro and run it off the receiver.
Hey, im now looking to buy a new set of headphones, and after reading around the forums, i thought this would be a great place to ask : )
After using the Koss Porta Pro's for a while, i decided to get something better, and thus i bought a pair of AKG 518 LE. They were quite nice, but unfortunately, it broke after just a week, thanks to the cheap plastic which isn't durable enough when collapsing them.
Now im looking for another pair, and i guess il probably get them for christmas.
So, these are my criteria;
* Im willing to spend about 1000 NOK (Norwegian currency), which is approximately 200 USD.
* Must be collapsible, so that i can bring them with me when they aren't around my neck or on my head.
* Cant look too ****ty, but i do not consider the retro look of the Porta Pro's or the Grado headphones ugly, but i dont like the looks of some studio headphones.
* I will definitively use them at school, which means they cant leak that much sound, atleast not as much as the Porta Pro's.
* They will also be used quite alot on busses, and occasionally on trains and airplanes, so they cant let too much sound get in either.
* I mostly listen to Hip-Hop (Lil Wayne, Eminem, 50 Cent, Ky-Mani/Damian Marley), some Dubstep, and sometimes Reggae (as in Bob Marley)
* Oh, i forgot, i will be using them with my laptop and my Iphone, so no amp, atleast not at this time.
* Im not really sure if i want over-ear or on-ear, as long as they fullfill the criteria it doesnt really matter that much.
I've been looking at the Grado SR-60i and SR-80i, thou they would probably leak to much for my use? How much do they leak compared to the Porta Pro's?
I've also been looking at the Audio Technica ATH-M50, do anyone have any experience with them?
So what would you guys recommend?
The grados are terrible for your use and are practically louder on the outside than in.
How about the bigger AKG K181?
So i wanted to get a decent pair of headphones after my Bose Triports got ruined.So after fishing around i finally settled on the Shure HD440 but i head that it needs to be amped to get the best out of it.After that i had settled on the MS1-i since i heard it sounds pretty good unamped and people seem to like it quite a bit.I plan
on getting a Cowan J3 later on and the headphones as well.but i head the sound quality of the j3 is good enough to use the shure ones without an amp.
Music wise i listen to rock,metal,a tiny bit of instrumental(say 5-7%).Nothing mainstream.Is there a decent set of headphones around the same pricerange
other than the 2 i considered?I also head the HD440s are a bit on the weaker side when it comes to rock music and such.I plan to use it on the j3 and my laptop as well.
Dont care about sound leakage btw![]()
Not sure where you heard that the 440 needs an amp... even the 840 does just fine without one. Around the same pricepoint, you could also consider the Sony V6/7506.
Hi guru's. I have a problem but it's a good one. I have put away roughly $300US over the last couple of months and need headphones to replace and compliment what I already have/had. From top to bottom in the last few years I have or have owned ATH-AD700's (still primary @ my desktop) AKG Q350 (stolen) which were top ear buds and I really miss, Klipsch s4's (broken), Sony MDR-NC22's (bought in target for $20 in pinkthat still work), Koss Porta Pro (broken) and I'm currently using cheap Sony Fontopia's on my journey to and from work with a FiiO E5 that is completely unnecessary for them but looks cool. I thought I wanted IEM's next, but now I seem to be veering towards OE's.
I primarily listen to jazz, rock and metal, some funky soulful house and a little classical but I also listen to a lot of podcasts (SGU, Skeptoid, Geologic, Stone pages, Monster Talk). I need a set of cans or great IEM's that give good isolation, have a neutral signature I can EQ through my Galaxy SII and Power Amp and a small physical profile. I always seem to punish in ears a damn site more than on ears so I've been really looking at the HD 25 1-ii, the TMA-1's and the DT1350's but I'm open to suggestions on IEM's and alternatives also.
Looking forward to your replys.
I just so happen to be finishing up a review of those cans that you're looking at... http://www.head-fi.org/t/574617/review-comparison-beyerdynamic-dt1350-t50p-sennheiser-hd25-1-ii-hd25-13-ii-pioneer-hdj-2000-v-moda-m80-aiaiai-tma-1-in-progress
I haven't quite finished with my notes on the M80 and TMA-1 yet, but you can get a sense of them.
A Studio Monitor headphone thats also immersive and has a little thicker bass, limit $70.
Sony V6?
I'm looking for a good full sized phone to plug into my Cowon j3 without an amp. I use Grado 225s primarily, wanting something with a little more soundstage/bass. $300 is absolutely the highest I'd go, but bang- for- the- buck is also a goal of mine. Open or closed doesnt matter. I'd like to be able to listen to classical, some techno/dance with these things. Thoughts?
If you like your current sound, get a SR60 pop it open and rip out the cloth and punch a couple holes along the vents surrounding the driver. That should bring up your bass and soundstage.
