Panasonic hj 329 >> is it worth for the price?
Wanna try but, It's almost twice the e600
If you are looking on value for money, then I'll suggest you keep the E600 instead.
Actually I would think earbuds are not a particularly good choice for monitoring / mixing. None of them really has flat enough response and the result of mixing might end up sounding very different on loudspeaker.
That would be an opinion with how many musicians use earbuds for live performances.
I've received the Mrice E100 headphones yesterday.
For the moment all that I can say is that they sound rich and very dynamic.
They also have a high sensitivity, which can cause noise issues depending on your source.
I think I'll stop with these acquisitions. There's nothing that special, it's all a matter of taste.
I want to buy a pair of on-ears similar to PX-100, but more airy, and I'm done.
