AntBoi1609
Thanks for the reply, I’ve been seeing a lot hype around the yincrow RW2000/3000 but $150-$300 is a little steep IMO for earbuds but I’m willing to fall down this rabbit hole.For the money I think the FF1 are probably the best sound you will get with an inline mic (AFAIK). I am sure there plenty of others out there, but I am not sure I would call them better or not.
Having said that, you could order something with a replaceable cable (i.e. Yincrow RW2000, RW3000, etc..) that you simply need to buy a cheap cable online (that has a mic), and replace the stock cable with.
Do you recommend any specific cables with in line mics?
