Doesn't look like it is on their website. Where can I find more details?A new bud from Venture. And trust me, sounds amazing.
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
Thank you very much!They are not the same model. The bell-lb(aka LBB) and bell-lbs(aka LBBS).
The black one without the mic (LBBS) have a better audio output.
Dr. Cube
I got the best results using a hammered punch set. It's much easier to ensure you get the punch all the way through the foam on the whole circumference of the hole than using a handheld squeeze punch.What's the best way fo making holes into the foams?
fooltoque
This earbud with one of the cables below should be good right?
Not good. The top cable (XINHS) would be fine if you select the mmcx option. MMCX is the connector for your earbud. The cable shown in the picture has a 2-pin connector, which is another popular style of connector. Please also note that this cable has a semi-hard plastic close to the connector, which is meant to guide the cable over the top of your ear. If you want the earbud to hang down like a normal earbud cable instead of go over your ear, you would have to remove that plastic. Not super hard but if you're not used to it you could easily damage the cable trying to remove it. I wouldn't recommend trying it, and instead get cables that don't have that guide.
The second cable you showed has no connectors at all, so it is meant for those who intend to make their own cables. It doesn't sound like that is you.
Here is an example of a cable you should be looking for. Note that it is MMCX. The cable is also straight, with no shape or guide close to the ears.
Make sure that the connector at the other end also fits whatever you're plugging into. In this case I selected 3.5mm stereo, which is the most common.
Please note that I don't know anything about this cable except what I see, so I don't know anything about it's quality. It's just an example that would fit your earbuds.
If you want a cheap good cable.This earbud with one of the cables below should be good right?
RY-C3 1.2m DIY Replacement Mmcx/0.78mm 2pin 3.5/2.5/4.4mm Silver plated Upgraded 8 core cable For RY4S plus mmcx earphone cable
https://a.aliexpress.com/_mr6qjnm
10DeeQ
- Jan 6, 2013
First modern earbuds for me, they sounded good,
A bit too bassy and too dark for my taste but its good for a change when my ears are tired of being stuffed with the IEMs
FlacFan
- Mar 10, 2015
@10DeeQ : How hard is it to share what we are looking at?
10DeeQ
- Jan 6, 2013
Sorry, its a fiio ff3 with sony wm1am2@10DeeQ : How hard is it to share what we are looking at?
You shouldn't be sorry.Sorry, its a fiio ff3 with sony wm1am2
There are more civil ways of looking for information instead of implying incompetence of the OP. That's low-key bullying.@10DeeQ : How hard is it to share what we are looking at?
Yeah that was very uncalled for especially when the FF3 is very distinct. It's not like you have regular MX500 shells here with custom drivers lol.
Charlyro222
Will be aviable soonDoesn't look like it is on their website. Where can I find more details?
A new fan of Earbuds, my first one Serratus and waiting to SUNNIVA..
And for outside listening, I didn't hesitate to buy the W4, which I received yesterday.
My very first test/1 album, via iPhone and Roon ARC is perfect to my ears, to be followed on my library...
prakasitp
About to order Yinman 600 ohm, is this shop is ok?
https://a.aliexpress.com/_mqWvHnq
They sent sample photo, But doesn’t look like the one that i saw in this group.
So I’m not sure this is same Yinman that every talk about.
silverszi
that's what the yinman 600 looks likeAbout to order Yinman 600 ohm, is this shop is ok?
they changed the box a few months ago that's it
Total: 28 (members: 1, guests: 27)
