assassin10000
That would indeed be a cool experiment, but is there even enough room to put a crossover in there? I hope you DO get time to do this, because I would love to hear how it goes.
In the meantime, figure out how to fix the sound on the M4 would ya'??? ROFL In all seriousness though, I don't hold out much hope for the M4 because there is just NO room between the driver and the back of the shell other than the tiny hole where the filter goes (which doesn't help the upper mid "ice pick" BTW (at least not enough to make a difference).
The problem with this is that I absolutely love everything about the M4 EXCEPT the sound, and even that wouldn't be so bad if they didn't hurt to listen to them...![]()
Depending on design could be as simple as a small resistor and/or capacitor. So definitely doable...
For the m4, maybe some extra porting?
