waynes world
- Jun 21, 2012
Concur with @samandhi that these earbuds scale!
I really do believe that their rated sensitivity of 95dB ±3dB/mW is quite conservative as I am finding them to be much harder to drive than even my Puresounds PS100-600S which were listed as 600Ω @ 93dB ±3dB/mW but were actually sub 93 dB/mW in true sensitivity. So I am thinking that these new Yinman 600Ω earbuds are probably closer to 91(90-92)dB/mW in sensitivity rather than their specified 95dB/mW. Some food for thought insomuch that they will and do scale incredibly well when fed more power. These are most excellent drivers as I am unable to make them distort with power or reasonable volume increases... unless via exuberant EQ'ing of the lower frequencies which of course is cruel and unusual punishment for any earbuds.
2022 Longyao-Yinman 2.0 600 LE; 600Ω
110db SPL Power Requirement if indeed 600Ω @ 93dB ±3dB/mW: 110db SPL Power Requirement if 600Ω @ 91dB ±3dB/mW instead:~4.4Vrms @ 31.62 mW is required ~6.9Vrms @79.43 mW is required
Now the above charts do not tell the whole story nor does it accurately depict a driver's true power requirements fat all/certain frequencies at different volume levels.
With that said although my Yinman 600 are singing with 9 plus volts (Vrms) from my custom earbud tube amp they are still performing admirably well on my lower gain setting @ ~3-3.5Vrms with no anemic or lost bass or flat sounding response. As I had mentioned before tried them with my Meizu HiFI Pro dongle "tricked" via an adapter cable to max output @ ~2Vrms with a thrust of ~9mW. They sound great with plenty of volume to spare. Bass is less detailed and less impactful but definitely they still remain very musical and energetic... not flat or deflated sounding at all to me like some other 500Ω and 600Ω drivers can be with lower power. Chalk that up to quality drivers being used by Yinman. This of course may simply be a synergy event as @samandhi has so rightly pointed out and results may vary from source to source.
As I ordered the single-ended 3.5TRS version as I listen at my desk on my tube amp with plenty of power-at-hand I am unfortunately unable to test them via my stolen (the wife swiped it) FiiO BTR5's balanced output on high gain mode.
Your best bet is to ensure that you order the balanced version so as to take advantage of Qudelix 5K's 4Vrms Balanced Mode which I honestly believe would offer enough juice for them to perform very well... but again if you can feed them more power, do so!
Thanks! Yes, balanced/4Vrms it would be for sure. Now for penny saving mode lol.
