I guess thats a silicone hook. But yeah, it looks very ehm...unique.
Maybe you can take off by placing them on the ears....
My smabat ST20 were delivered this morning. Corner of the box took a beating in transit, but visually, all seems good. Gonna try to make time tonight to give them a listen. I specifically requested a 4.4mm balanced termination.
Waiting forward your impressions, mine is still on wayMy smabat ST20 were delivered this morning. Corner of the box took a beating in transit, but visually, all seems good. Gonna try to make time tonight to give them a listen. I specifically requested a 4.4mm balanced termination.
So Tempted by RW2000 but a bit scared by fit...
I like midbass emphasis and in general more bass than neutral buds, so RW2000 should be my cup of tea considering also it is easy to drive with W2 or RS6.
Ok i go with it, do you know where can i buy for a good price?RW2000's fit is quite good, at least for my average sized ears. They can be worn cable down or even over ears, so quite a few permutations in terms of fit. Or even if the earbuds feel quite loose in the ear, one can use double foams or silicone hooks/covers to add heft to the fit (these might change the sound signature a bit though).
Re: smabat St20Any first impressions on the sound? TIA!
It's good that you have recovered.Re: smabat St20
I am really hesitant to comment on sound as I have just "come back" from an ear infection (first time since I was a small child!!!) in both ears for almost 2.5 weeks. It actually forced me to buy a set of over ear headphones (I am not a headphone guy, and hadn't even had cans in my possession for almost 10 months) last week, so the only music listening I had done before last night was using my new cans for like 3 days prior, hahaha.
I am willing to say that I THINK this set especially will benefit from some burn-in. I noted a significant upper mid/lower treble harshness that sure seemed to diminish over the few hours I had these playing out of both my WM1A (for music) and L&P W2 (connected to my Macbook Pro to watch a tv show).
Cheapest I have found them are from here on Aliexpress. I can't speak to the reputation of the store because I bought them from the NiceHCK store on Aliexpress (which they have them also but are about $10 more).Ok i go with it, do you know where can i buy for a good price?
yeah I was looking that store and VS Audio at same price… anyway I think I’d wait because I’m ****ed, today I received this bad red guy and I can’t stop to listen it, unfortunately isn’t mineCheapest I have found them are from here on Aliexpress. I can't speak to the reputation of the store because I bought them from the NiceHCK store on Aliexpress (which they have them also but are about $10 more).
SWEET!yeah I was looking that store and VS Audio at same price… anyway I think I’d wait because I’m ****ed, today I received this bad red guy and I can’t stop to listen it, unfortunately isn’t mine
