you might be experiencing a little Audiophilia Nervosa.
I LOL'ed. Thanks for that! The urban dictionary defines that as:
the anxiety resulting from the never-ending quest to obtain the ultimate performance from one's stereo system by means of employing state-of-the-art components, cables, and the use of certain 'tweaks.
While I agree that I should not be able to hear that small of an imbalance, I am hearing it (pretty noticeable too). Maybe the slider in Neutron Player isn't measured in dB (matter of fact, I would bet that it isn't because I can change it from -.25 to -.30 and hear a noticeable difference)???
Edit: My mistake, Neutron balance level is measured in -1, 0, and +1 (makes more sense seeing that).
I guess I just got used to it, insomuch as adjusting the left bud, thinking it was not in an equal spot (physically) in comparison to the right bud. But, once switching ears, it was clear that the volume coming from the right was not equal to the left. I dunno', but I am not so worried about it for now, it is if it gets worse and by then they are out of warranty.
Hmm, I just had a thought. Maybe I should take the foams off and check and see if it is clogged a bit? I sure hope not. If it is, that means I must have poor ear hygene... LOL
What is the threshold of when ur brain stops compensating for channel imbalance when using headphones/earphones? I'm sure it does doesn't it?
Exactly why I changed ears. But I would guess it is right at the level that
@baskingshark mentioned. I don't really know either way, but I know that I can listen to them for an hour, or four hours, and I will (subconsciously, and continuously) adjust the position of the bud.
On another note, as a good surprise to me, my EB2s are due to be here tomorrow with the mail. Color me shocked.
