Hi gang, I've been enjoying my Datura Pro for a couple of months now. Which were also a recommendation from this thread, so thanks for that. They still work fine, but the shell tends to pop loose every once in a while on both sides. While I'm gonna try and fix it with some glue or tape, I am going to use this as an
excuse opportunity to get myself something new to play around with
On that note, I was wondering what buds are the deals of the moment right now? I quite like the Datura Pros, I run them straight off my smartphone, using wavelet to just a little bit to the bass/low end. But apparently they're out of production. I've seen the Bell-LBS pop up a few times in the thread over the past pages. Also the Smabat modular pieces. Let me start off with the template.
- source Redmi Note 8 -> VE Odyssey dongle dac
- preferred connection 3.5SE
- listening level & time Usually 35-ish% volume with my current buds, for anywhere between half an hour to a couple of hours at a time
- listening environment Strictly at home, a lot of it during the evening and at night in a quiet room
- preferred sound signature I think smooth and slightly warm? I'm unsure how to really describe it. I like to hear everything, including the little aftersounds of the guitar strings for example, which is why I generally add a little bit of low end because otherwise that gets lost. I'm a bit sensitive to high sounds, so some headphones sound harsh to me when there's flutes and such.
To give some examples: For headphones I still enjoy my HD555's, K701 (if EQ'd through wavelet), KSC75 and KPH30i. I've had a shure srh440, but they sounded too dry for me. I've also had portapros but those were just a bit too dark for my taste.
For earbuds, I liked the OG monks, the niceHK B40, and the datura. I did not like the monk+ or the ME80's. Though granted, I may have gotten a dud or a knockoff of the ME80, since they sounded truly awful, just very harsh and thin with absolutely no low end.
- preferred genre Usage will be mostly OST's, Piano/Guitar pieces with vocals, Metal and podcasts. With a healthy dose of electronic music and jazz thrown in there.
- preferred shell type none
- preferred brand none
- price range (Up to 50 euro for sure. I might go to 100 if there's a truly stellar option.
The Smabat pieces seem nice. 30-ish euro for M0 shell + cable + 40ohm driver. Though I'm unsure what effect the two different shells have, considering the other one is almost 3 times the price.
So far I haven't really looked at higher ohm drivers/buds (like the 100/150ohm Smabats) since I'm unsure if running them through my phone+dongle dac will give enough juice.
Any recommendations or tips are appreciated.
