No, this driver has MX760 cover and fits DP100, Hybrid and MX760 shell. This one is for MX500, but I don't know how it sounds like in this shell.So far..
Would this driver fit in this shell? https://www.aliexpress.com/item/32981145439.html it comes with 5 pairs and with foam pads already :#
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
Ah, so the ShoonTH uses Foster drivers? I remember being disappointed by the Foster drivers in the Ocean Pearl 139. I really wanted to like that one.These models use ShoonTH (Foster) driver but this shell is hybrid, something in between MX500 and DP100.
NOTE: Never ever use drag n drop method of tuning in this.
@jeejack went a little further with this model and made an MMCX version as well
poczta6788
Okay, any suggestions? :# I will resell extra pairs.No, this driver has MX760 cover and fits DP100, Hybrid and MX760 shell. This one is for MX500, but I don't know how it sounds like in this shell.
I'm in talks with Wong, he has not gotten to retune the 400ohm drivers yet, so we'll how that plays out.If you're ever in the market again for more Blur, check out the OFC MX64 aPs Special Tuning Edition. Sounds like it would be your cup of tea!
Hope you enjoy your new buds!
Close! It's a Nunu.I scrolled passed the picture and recognized something, had to scroll back to see what is it that looks familiar.
Is that an alice?!
Are you plan to build few pairs or just one?Okay, any suggestions? :# I will resell extra pairs.
Only difference is that OG ShoonTH buds use the best samples of these drivers. I see Ocean Pearl 139 use 44ohm driver and MX500 cover and shell.Ah, so the ShoonTH uses Foster drivers? I remember being disappointed by the Foster drivers in the Ocean Pearl 139. I really wanted to like that one.
This one has different spec and it's 32ohm.
The cable you picked is very stiff and easily break near the plug.
I suggest you spend a little bit more and get higher quality cables like the ones suggested by furyossa or something like this
https://www.aliexpress.com/item/32820539003.html?spm=a2g0o.cart.0.0.65713c00GfXpIg&mp=1
This cable is really good if you are on a budget https://www.aliexpress.com/item/32932216968.html?spm=a2g0o.cart.0.0.3a483c00jzHmHD&mp=1
At the same price or less you might also consider testing 2-3 different cheap drivers instead of assembling 5 identical earbuds.
From the same store:
https://www.aliexpress.com/item/400...store_pc_allProduct.8148356.17.6cca23d3kD6pYk
https://www.aliexpress.com/item/329...store_pc_allProduct.8148356.27.6cca23d3kD6pYk
https://www.aliexpress.com/item/400....store_pc_allProduct.8148356.1.6cca23d3kD6pYk (Good fun set, 32ohm)
https://www.aliexpress.com/item/400...store_pc_allProduct.8148356.11.6cca23d3kD6pYk (Faaeal rosemary drivers, 150ohm)
Ah, I see. Ok. Thanks for the clarification. Although if I do recall correctly, the Ocean Pearl 139 is a slightly-modified MX500 shell, namely the stem and the part where it flares out to the face. The rest, appears to be identical.Only difference is that OG ShoonTH buds use the best samples of these drivers. I see Ocean Pearl 139 use 44ohm driver and MX500 cover and shell.
The question is whether he wants to build just one model or plans to embark on a serious DIY work.The cable you picked is very stiff and easily break near the plug.
I don’t want to waste time and recommend a bunch of things if there’s no need
poczta6788
Spending 12$ for one pair | Spending 33$ for 4/5 pairs and resell them | Spending 28$ for 3 different earbuds and resell the one i don't like?
Why are you asking us? Just choose: red or blue pill
You sound like me...roughly 1000$ ago
Just buy an X6 Link
poczta6788
I always have problem with final decision xd. **** it, will take 4 pairs of MX760.
Just tell me which cable is more durable, if they are at same level, which is lighter?
https://www.aliexpress.com/item/33017721516.html
https://www.aliexpress.com/item/4000908606284.html
RY cable: lighter, softer and have better build quality (better plug and workmanship + higher quality copper)I always have problem with final decision xd. **** it, will take 4 pairs of MX760.
Fabric cable: more durable and easier to solder (less brittle tin).
Sound wise there isn't much difference, it's more a matter of look and price.
I'd pick the RY cable if you plan to use them indoor otherwise the fabric cable.
The fabric cable from that link have a 4-pole jack, i suggest getting the 3-pole standard jack.
Side by side comparison:
RY cables are really great. I test them all and never had a problem with themRY cable: lighter, softer and have better build quality (better plug and workmanship + higher quality copper)
Total: 117 (members: 24, guests: 93)
