Which version? They lack low end, especially sub-bassLCP sounds so good
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
Its a 32 ohm. This one has low end. Its been tuned well. Newbsound LCPWhich version? They lack low end, especially sub-bass
Any link? I'm playing with 120ohm, and I'm trying to find the way to bring bass to lifeIts a 32 ohm. This one has low end. Its been tuned well. Newbsound LCP
Its not made by meAny link? I'm playing with 120ohm, and I'm trying to find the way to bring bass to life
MelodyMood
Brother. Is there any other MMCX Cable you can suggest? I ordered one from FAAEAL and it's almost 50 days but it has not arrived yet. They lost tracking and no further update for last 1 month. I need a cable which can be delivered faster. There is one on Ebay: https://www.ebay.com.au/itm/255075978119?hash=item3b63b68b87:g:M5cAAOSw4pRhCNgAYou will need to order the cable separately for this RY4S Plus.
Did you not like this MMCX cable I recommended?
https://www.aliexpress.com/item/1005002103784716.html
I don't have the MMCX cable with mic, so if you want a different cable, please search for "MMCX cable with mic" in the Ali search field.
But I am preferring Cable with Single Click Mic and Straight Plug (the one form ebay has straight plug though).
Can you (or anyone else) suggest MMCX with Mic (straight Plug and Single Click Mic). AE does not seem to have any such with faster delivery option so any other site will be fine too. Thanks in advance.
EquationTo think I must have gotten it off easy (so far) with a small handful. Definitely counting my blessings
Before you mention it, yep, one of those wire runs has a snip through it. Oops. Hope those other cables show up soon.
Don't know how he does it, but Mr. James does stuff in the stereo space that defies the laws of (recording) physics. I'm sure this waveform is pretty popular by now:
No, that's not a photoshop. Yes, it's mildly creepy. He's still a genius for figuring out how to do that in the first place.
Ok, that's why I ask about the link. Where did you get them?Its not made by me
Ronion
- May 17, 2013
I keep thinking about that same driver….. if the 14mm goes better than I expect it to, I’ll likely get it.If having the M2S Pro (stock) and the ST10S gold are any indication of the differences; wait until you get the 150Ohm driver... I may have to try the super one driver (just for kicks) on the M2S Pro.
+1
MelodyMood
Any suggestion for MMCX Cable with Single Click Mic option and also faster delivery to Australia? AE or any other site is fine.
It's made by a user here. @irv003Ok, that's why I ask about the link. Where did you get them?
Thanks for the info.It's made by a user here. @irv003
VE Monk Slim Metal - Very impressed with these, they are worth far more than $20.
To my ears, the sound signature is neutral-bright. All aspects of the sound is good, clean and detailed, wide soundstage. It does have a thinner presentation when used with a neutral source so I would suggest a warmer source.
They do have a bright treble, more than what I am used to, they will be more fatiguing at higher volumes for sure but I don't detect any harshness, the brightness is in the treble region only and does not affect the upper mids, when those treble notes are hit just right it gives me a tingling sensation.
No problem Some of the best earbuds I've heard.Thanks for the info.
I just realized I had posted the wrong photo . These are actually the LCP. They look similar. Still sound so goodThanks for the info.
Are you sure that you're using right model?I just realized I had posted the wrong photo . These are actually the LCP. They look similar. Still sound so good
Total: 77 (members: 16, guests: 61)
