siderak
Ha ha for sure!!!This is called good QC check!
"Wash in" is the new Burn in!
hypoallergenic scent free detergent in case anyone was wondering…
I guess there really IS a hands off approach to washing those foams.Ha ha for sure!!!
I've been listening to classical piano music with this combo (120Ohm driver) for a full battery length on the Little Bear and it's the closest thing I've had to a religious experience in a while. I needed it! Can you delve more deeply into the difference(s) with the better op amps and have you tried others?
Now this is a nice, mellow combo for a Sunday afternoon. The M2s foams are starting to get softer and more plush. Midbass is starting to round out, though there's still too much of ahumptrough in the upper bass that's throwing my ears off. There's some really close moments with strummed acoustic guitars here until you realize some of the fundamentals aren't there. It's close, though, and really impressive if your ears aren't quite as spoiled.
For under $100, though, it's an amazing performance. I highly recommend![]()
My prediction for 2025 is that the "Earbud" cycle will be a standard feature on all high end washing machines with lesser machines equipped with and "IEM" mode internationally. Just saying.
Query: I noticed that there are many options of JCALLY Earbuds. EP01, EP02, EP05, EP08 and EP09. Not sure if there are 04, 06 etc. also there or not. My query is, which is the best in them in terms of sound quality and build quality. Also, EP05 has MMCX Connector Cable, however, I am not sure abt the cable quality and also do not like L Shape 3.5mm Plug and prefer straight one. Is it possible to buy only the Earbud and not cable if I decide to buy EP05? Otherwise which is better option for beautiful Airy sound with good Bass and clear but not harsh vocals and trebles.
(I smuggled them in when the wife went out to the market shhhhhh).
Exactly.So the shell housing/material and perhaps dampers inside do affect the sound, even with the same drivers used.
Not so much the differences between, but here's a good writeup from Sparkos as to why they matter:I've been listening to classical piano music with this combo (120Ohm driver) for a full battery length on the Little Bear and it's the closest thing I've had to a religious experience in a while. I needed it! Can you delve more deeply into the difference(s) with the better op amps and have you tried others?
https://sparkoslabs.com/discrete-op-amps/
I'll leave someone more experienced than I to explain the differences between a MUSES02 and V6 Vivid, but the biggest differentiator in our cases seems to be power handling. I had a choice between the V5i-D and the V6 to test out, but since this is a battery-powered unit, didn't want to affect battery life too much and opted for the V5i-D.
But these tubes do wonderful things to guitars, strings, and pianos (the grander, the greater). Throw some cello tracks on it and get ready for chills:
Was trying to figure out who would appreciate it. Glad you did! This is just beautiful music. Album is in my buy queue as wellThank you for sharing that Rose Riebl piano track. I bought it!
