Earbuds Round-Up
Jul 14, 2021 at 10:33 AM Post #56,131 of 75,463
My M2S Pro finally arrived. Gonna be listening to the for the rest of the day and will try to compare the Golden Driver (150ohm) vs the stock one (40ohm). So far I'm loving them. Already my favourite on my small and cheap collection for sure.
Jul 14, 2021 at 10:40 AM Post #56,132 of 75,463
I think this is just because of look :wink:
Jul 14, 2021 at 10:47 AM Post #56,134 of 75,463
Jul 14, 2021 at 10:52 AM Post #56,135 of 75,463
Don't look at me, I don't have them, just support @RikudouGoku opinion :wink:
The Yincrowd is getting bigger and bigger.
Here is another iem user I managed to capture lol.
(from my discord server.)
Jul 14, 2021 at 11:47 AM Post #56,137 of 75,463
I'm not that easy:stuck_out_tongue_winking_eye: probably because I'm not an IEM user. Anyway, I admire your persistence.
Jul 14, 2021 at 11:50 AM Post #56,138 of 75,463
Yeah, price performance on the X6 is one of the highest in the hobby. godlike
There are many like that if we are looking value vs price, it all depends on your personal taste:beerchug:
Jul 14, 2021 at 11:50 AM Post #56,139 of 75,463
the matching cable tho SHEEEEEeeeeesh
are you actually rocking them without foam or just for the photos?
Jul 14, 2021 at 11:54 AM Post #56,140 of 75,463
He just shows how good they look. Killer photo for sure:thumbsup:
Jul 14, 2021 at 11:57 AM Post #56,141 of 75,463
I assume that's not the stock cable, then. Any recommendations? Have a couple NICEHCK 16-core units, but would really like to find something thin and light without having to go full BaX. She's definitely photogenic.
M2s Pro are somewhere in transit. Got a shipping notice for the Monk Lite SPC 120ohm from VE. Now we play the waiting game.
Jul 14, 2021 at 12:00 PM Post #56,142 of 75,463
Great! Thanks for sharing your views of the Zen LL. How are the highs on the LL? Rolled off or well extended? Would you say the sound sig to be balanced, or warm tending towards dark?
Quite some talk of the LBBs recently. I might have to bust out mine just to revisit it. Pity the fit is very poor in my case.
Good question. Highs on the Zen LL are well extended, though smooth and not harsh or sibilant even on high volume.
The sound signature is rather balanced, somewhat warm, some people would call it analog sounding :wink:. I would not call it dark, and I define dark as rolled off highs with stronger low end emphasis.
Even the resolution is pretty good.
I would say it pairs superbly with E1DA 9038D, which has non-colored highly detailed output.
@sfrsfr Do you mean the SLQ version?
I have only the Standard version of Zen LL.
Jul 14, 2021 at 12:07 PM Post #56,143 of 75,463
Nope, thats my cable built and sold by XINHS. (Cable A25 on my list)
Check out XINHS they got a ton of cables.
Jul 14, 2021 at 12:13 PM Post #56,144 of 75,463
Yeah, it's not the stock cable. It's a 4.4m balanced cable I ordered custom form Xihns (got a 2 pin and a MMCX). All credits go to @RikudouGoku for the rec. You can see it on his list here (it's the A25).
Any recommendations? Trying to listen as much as I can, only got in the rabbit hole 1 month ago. Wanna try to experience as much as I can :)
I usually prefer donut foams, but depends on the model. On X6 I use full foams (non-thick ones). Guess it's about my sound preferences. With the 150ohm driver I'm using full foam, with 40ohm i'm using donuts so far.
Jul 14, 2021 at 12:19 PM Post #56,145 of 75,463
They're the OEM for NICEHCK, right? Thought I heard something in the past connecting the two. Their cables are quite nice; been eyeing some of the 4-core models myself. Good to know they're a smart choice.
