Something about K's buds
#1 #2. Ksearphone Bell-LB look similar as Bell-Ti, but there is a difference.
If we look closely at the shell, we can see that the driver, i.e. the cover, is slightly wider so that it does not merge in line with the shell, which is the case with the Bell-Ti model. The diameter is slightly increased, but this stepped transition prevents fall of the foam. As for the stem, usually when we have the same shell, if we have a longer stem length, then more pressure is created and therefore the low frequencies are more pronounced. But here is a slightly specific case, the driver is different and is probably tuned differently. Now there is one small detail that is also important and that is the cables. On Bell-LB one strand passes through the stem. The opening on the stem is a bit narrower so that the space where the air passes is much smaller compared to the Bel-Ti where the two thinner strand passing through a wider stem.
This way both shells can have the same pressure inside.
#3. Bending the cable more than 75 degrees can damage the cable. Unlike the Bell-LB model, the Bell-Ti has a sharp edge on the stem that can cut the wire.
Another case is pulling which can unsolder the cables or damage the driver inside. To avoid this, a knot is made at the end of the cable that blocks the pull-out, but this knot also takes up a lot of internal space, so it is often avoided. Another way is to use
metal "U" Clips
#4. Since the Bell-Ti stem is used as a bass vent, we must take care not to close it. It can be cut small piece of Pvc Electrical Insulation Tape, and wrap it around the edge of the stem. Leave a small overhang so that it can be twisted inwards. U can use "Red" and "Blue" as markers for the left and right sides
