renatopdalencar
Thank you!I don't have a frame of reference for the x6 or the mk2. I'll reply later tonight to this after I get home and A/B test for ya however
ST10s black gold>yincrow bass pro>tone king 600> tone king 400 > toneking dendro aspis viridis for bass alone.Thank you!
I saw them when i first started picking earbuds up, but avoided them because i couldn't find much in aftermarket support. Those ****'s look really good, any idea of the general consensus of those?Did you ever listen to the original modular earbud version the Smabat M2 Pro? Also, fairly recent are the ****** PT2021 (in multiple impedance versions 32/147/275/365Ω) and the NiceHCK EBX21.
@ClieOS spoke well of them and advises a higher impedance version if you have the power... since his post here there have been two (2) more impedance models added to the line 147Ω and 275Ω. Here are other posts where he mentions them: Post #1 and Post #2Those ****'s look really good, any idea of the general consensus of those?
The st10s it is, then. Thank you very much for the effortST10s black gold>yincrow bass pro>tone king 600> tone king 400 > toneking dendro aspis viridis for bass alone.
The yincrow's are very close bass wise to the st10s, but they pale in comparison over all to the st10's, and imo, are the weakest sounding objectively of the ones that I own. They're not bad, but they're also nothing special in comparison. The dendro's should be immediately thrown out of the picture even though they're my most used earbuds for overall use lol.
make sure you pick up the black golds. They're 150 ohm and sound vastly different to the other variants. They are significantly more expensive however.The ST10s it is, then. Thank you very much for the effort
Yep. Sorry I had to burst your bubble.hahah, damn.
I figured one of us would catch it.@assassin10000 see and knows the best
Yuin PK1 is available at Penon Audio, a reputable store.
https://penonaudio.com/earphones/earbuds/yuin-pk1.html
But look at this thread's author's Earbuds ranking from 5 years ago.
https://docs.google.com/document/d/1wGTZnKX1aP29c1bzs5JWgqSUlPzZqV9p_cw79VfRBpQ/pub
And this is Japanese Blogger's Earbuds ranking.
http://headphonemetal.ldblog.jp/archives/52320906.html
According to these ranking, Shozy Cygnus, which uses the exact same PK Shell, has a higher rating.
I also had the DIY earbuds of PK1 150ohm redfilm driver and the Shozy Cygnus, and I liked the Shozy Cygnus better because it didn't need an amp and it had a warmer, sparklier sound.
However, the cable of Shozy Cygnus turns green. If that doesn't bother you, I'd recommend this.
https://penonaudio.com/earphones/earbuds/shozy-cygnus.html
Glad i'm not the only person that's using earbuds on utws3's haha. I just picked up a second pair to permanently keep a pair on. Thanks for all the recommendations, lots of new stuff on my radar.@ClieOS spoke well of them and advises a higher impedance version if you have the power... since his post here there have been two (2) more impedance models added to the line 147Ω and 275Ω. Here are other posts where he mentions them: Post #1 and Post #2
A brief description directly from @ClieOS: "a little bit on the bright and analytical side, but not strictly a reference flat sound. Overall a very good sounding earbud for the price and could have almost compete with earbuds double the price."
Then I guess I'll need to upgrade my sources. I currently use my earbuds either directly on my phone (OnePlus 5T) or through a Sonata HD Pro.make sure you pick up the black golds. They're 150 ohm and sound vastly different to the other variants. They are significantly more expensive however.
they're sensitive enough to be driven by my motorola one ace. Use it as a dap that I can watch memes on . A sonata HD pro would work totally fine, and is what I used prior to picking up a qudelix, but they're driven to a comfortable volume by just 3.5 on a phone. Often use it in bed and I can't be assed to lose an adapter underneath my bed.Then I guess I'll need to upgrade my sources. I currently use my earbuds either directly on my phone (OnePlus 5T) or through a Sonata HD Pro.
The only problem with OnePlus 5T and Sonata HD will be fast drain of 3300mAh battery. Of course, the best solution so far has been offered by LG with its integrated QuadDAC chip, but recently the LG company decided to stop further development and production of mobile devices. Another non-budget solution are Sony Xperia 1 lineup or a bit budget friendly Xperia 5 and 10 lineup.they're sensitive enough to be driven by my motorola one ace. Use it as a dap that I can watch memes on . A sonata HD pro would work totally fine, and is what I used prior to picking up a qudelix, but they're driven to a comfortable volume by just 3.5 on a phone. Often use it in bed and I can't be assed to lose an adapter underneath my bed.
Hi Friends. I am looking for 1-2 earbuds to buy. I already have FiiO EM3S, Monk+, Yincraow X6, Musicmaker TP 16, Nicehck B40, and FAAEL Iris. I also had **** MS500. That was Ok too but lost. And had EdifierP180 too but that is lost too. All were/are with Mic only. Monk+ I bought 2nd time and it is also broken. Yincrow Mic does no work anymore. FiiO is good but I found that the cable is not that good and tangle a lot. Is there any suggestions which has at par sound quality of TP16 and Iris. I liked these two really much. Yincrow sound is good too but it is broken. Mic is most important factor for me to buy. I like Warm sound with good details and not harsh . And good Bass or even sub-bass is good. I wanted to buy TY Hi-Z 32 especially the red cable one but none is available with Mic. My budget is not very high so $5 to 15-20 is good range though. Thanks.
RY4S Plus or RY4S 300ohm version if you have DAC/Amp deviceI was considering KBear Stellar but seems the reviews are not that great so I am not sure. The comparison was done with the earbuds I do not have so not sure if it is good or not?
I do not have DAC. I use Mobile Phone and PowerrAmp to listen to the music. This one is not with cable. Is there any version with cable? Are they good? I saw few RYgmr also. Not sure if they are same or what? This one:RY4S Plus or RY4S 300ohm version if you have DAC/Amp device
https://www.aliexpress.com/item/33038850404.html
