I ordered the BLON BL03s and I can't for the life of me to get them to fit, but the sound is exactly what im looking for. Are there any buds anyone can recommend under the same budget and sound? I've been recommended Hifi Boy Dream so far so if there's no advances on that I'll give them a go. My preference would to be able to order from somewhere like amazon so I can do easy/free returns if they don't fit/I don't like the sound.
I say that the Yincrow X6 is the most similar, but of course both being different transducers, it is still going to be different (but I guess you know that).
Sony MDR-E9LPB
■ LP: L-Type Plug
■ B: Black Shell Color
■ Debut Year: 2010
■ Driver/Diaphragm: 13.5mm open air dynamic dome type; PET (Mylar); Neodymium magnet
■ Impedance: 16Ω
■ Sensitivity: 104dB/mW
■ Frequency Response: 18-22,000Hz
■ Max Power Input: 100mW
I have listened to two different pairs on separate occasions and they both sounded horrendous to me. Baffling as they were not Sony-like at all; very disappointing. YEMV.
The newer rebadged same internals model MDR-E10LP is just as bad if not worse sounding!
Sony MDR-E9LPB
■ LP: L-Type Plug
■ Debut Year: 2010
■ Impedance: 16Ω
Sony MDR-E9LPB
■ LP: L-Type Plug
■ Debut Year: 2010
■ Impedance: 16Ω
MDR-E9LPB is one of the ugliest earbuds I have ever seen. And not only do they not sound like Sony, but the design itself is hilarious.
It reminds me of those "gummy", "bubble" or whatever they called, series, coated with rubber in several colors. MDR-E10LPB are a little nicer especially with all these combinations. I can bet this model can be bought in any candy shop.
This one (JVC GUMMY HAF160) I tried ... 10 seconds and .... no comment. Colors palette are spectacular All these versions sound the same but taste different
And the winner is Panasonic without doubt. Looks like gum
When it comes to AKG I can freely say that the Y16A is one of the nice looking models - elegant form with precise arc contours. It is a pity that the sound quality is not at a higher level. Treble centric buds for sure.
Yeah they seem widely recommended, was hoping for something with a nicer material but I don't think you can really complain at that price. Would you still say X6 over the RW-9 if I prioritise bass? I do like a little rumble.
The RW-9 has more bass quantity than the X6 but at the cost of some quality to me. If that is fine for you, then go ahead with the RW-9 (it also has a better cable).
Ok here we go again vs
I agree. You compare buds that are 3 times cheaper than BL-03.
This is a great example because the BL-03 is almost 3 times better
Now let's compare earphones with similar hardware. DX5 vs BL-03.
Both models have DLC driver, metal shell. The main difference is that the DX5 is three times more expensive but in terms of sound quality (tuning), it is 1/3 of BL-03.
RY4S Plus is still champion with everything it offers for less than $10
the comparison with bl3 is only because you have indicated that you are looking for such a sound. But I can't give you the reason in this case. Regardless of the price, blon is reinforced in bass, but that is not synonymous with it being better. you have others at the same or similar price that sound just as good without those bass. It depends on your tastes. In my case, I can live without the swollen bass perfectly, and when I feel like something more forceful I look for blon or others (which for me there are better in this field).
To explain why I love this shark, it would take a long time and I think I would break the rule of this forum because this is a thread about dolphins.
Sometimes I'm afraid to turn up the sound on the sharks because I'm afraid they'll bite off my ears
The styling is just beautiful, exactly what id choose, but obviously interested in how they sound. I am most likely gonna order the X6 tonight anyway, but if I can have another pair with this metal casing style which sound good im all over them!
This is a very common issue, even on other audio manufacturer sites and on audio forums. I've seen a lot of folks interchangably using the terms IEMs, earbuds, earphones as an umbrella term to refer to any audio gear.
I guess only us folks in this thread will get worked up over the wrong terminology hahaha.
