Ok, I mentioned in my previous post how the BK2 graph highlights some things about earbuds that seem really confusing to understand in relation to IEMs and headphones.
Context
here
On Pinna Gain and Earbuds...
In case new users are not familiar with what "pinna gain" is, here's my explanation. The short description is along the lines of, "there should be a gain centered around 3khz because of how our ear hears sound." Without this gain, earphones will sound lifeless and flat. For the purposes of our earbuds discussion, it's worth digging a bit deeper into this pinna gain. Similar to pinna gain, is a concept of head gain where sound emanating from headphones pass through the ear even differently from IEMs and require a gain as well (different from IEMs, typically a bit higher in frequency). The differences between pinna and head gain are well understood and pretty obvious if you think about it -- iems, with their insertion into the ear canal, actually bypass the pinna which affects how we hear differently from headphones.
All this to say, this is why IEM curves are different from Headphone curves. But we already knew this.
One more thing to highlight with earbuds and target curves. There is also a pinna notch, typically around 10k but can occur anywhere between 6k to 15k. This notch is due to a combination of phase cancellation affects that occur as sound enters our ear. The impact of this phenomenon can result in some users having treble sensitivity -- these users' pinna notch may be much higher in the spectrum or less impactful to where they actually hear more treble because of less pinna cancellation. So when these users hear an IEM producing upper frequencies that are near a notch region (for other users) of the graph, it can be overwhelming and fatiguing. This can also explain why various dips and notches in measurements do not affect some users at all, while negatively affecting other users.
Back to Earbuds...
I'm left with these questions to explore.
- Should an earbud target mimic head gain over pinna gain?
- The BK2 has virtually no pinna gain, yet it sounds great in the upper mids. How?
- It there such a thing of an earbuds version of pinna gain, maybe we should coin the term, earbud gain?
- Since the bud rests outside of our ear canal how do earbud graphs interact with our pinna notch?
- Should there even be a pinna notch with earbuds?
- What about the Fletcher Munson contour? Does that even affect earbud users?
so many questions....
