prionsarebad
Thanks.Welcome and better take care of your wallet! Earbuds are a totally different ball game from IEMs and headphones. Good news is that they seem to be relatively cheaper than IEMs and cans, though perhaps they suffer at isolation and possibly subbass. @RikudouGoku is right, better find something that fits you first before u dig deeper down the earbuds rabbithole.
If u are getting the RY4S, do note there are a few variants:
- regular RY4S 32 ohm
- RY4S 32 ohm plus ---> bassier version of the RY4S 32 ohm regular. So so for the price of $8ish USD, the midbass and subbass is quite good for a bud. Though the bass is boomy with midbass bleed (and ain't tight). Upper mids a bit hot.
- RY4S 300 ohm plus ---> much more balanced than the 32 ohm plus, less midbass quantity and subbass extension but the bass is tight and accurate with no midbass bleed. There may be a tinge of spiciness in the upper mids but it is more managable for me than the 32 ohm plus. Techincalities are quite good, though it needs amping as the impedance suggests.
I don't have the SMABAT ST10S black gold/black silver, but I have the regular SMABAT ST10 and it is my most used bud now. Great subbass extension for a bud and good technicalities. Fit may be a problem if u have smaller ears, but it can be worn cable up or down so do explore.
Something like the BK2 is also not bad for $21 USD, well balanced, above average technicalities, though soundstage is weak and bass is a bit light for me.
Ok, learning your personal fit size makes perfect sense, of course.
so the Iris 2.0 fit fine and they are 15.4mm.....if i get the snow lotus 1.0+ they are also 15.4mm so i don't learn anything new.
The smabat are also 15.4mm.....am i missing something here or do some earbuds come in larger sizes than 15.4mm? Thanks.
