DBaldock9
You need that new shiny golden toy
Hear, Hear!
You need that new shiny golden toySo anyone have the new Smabat ST-10s in ear yet? Smabat is my favorite as far as earbuds. I have both the M1 Pro as well as St-10(wearing them now). The new graph from the company shows some bass shift and I am not sure what else to expect. I know they made the bass chamber bigger and the two ohm types. Since I mostly do things from my Dell laptop I will probably just do the Silver unless Gold is really that much better then I'll be going for the gold. Overall still really happy with the old order Smabat kit but of course I am pulled in by the new shiny things.
Hear, Hear!
m1pro has a smaller driver 14.1 mm than 14.8 bk'sI wish someone would make an Smabat-style earbud but use a PK shell at the end instead of that almost 16mm monstrosity.
I have recently ordered the Final Audio E2000 ( I know, they are IEM's and not earbuds). For fun, after burn in, I'll test them against my Shozy BKs which have been my main daily drivers.
Also, had to have my Shozy BKs fixed by an engineer buddy of mine since Shozy was non-responsive when I asked to have them repaired (even told them I'd pay). That was the last time I spend really anything over $50 on earphones without detachable cables. They sound great, but I just know they will die at some point.
Awesome! I have put these on my wish list. Will look up some reviews and see what the sound signature and quality are like. The BKs are basically TOTL earbuds for me--so, the real reason I would replace them is because I can get an equal quality of sound with detachable cables.m1pro has a smaller driver 14.1 mm than 14.8 bk's
Try the final audio design A8000Awesome! I have put these on my wish list. Will look up some reviews and see what the sound signature and quality are like. The BKs are basically TOTL earbuds for me--so, the real reason I would replace them is because I can get an equal quality of sound with detachable cables.
I'd never spend that kind of money on any headphones ($2,000). If I was going to buy a TOTL IEM, I'd probably buy the latest Flare as it too uses a Berilyum driver and most reviewers believe it is better than Campfire's offerings. Also, I don't like IEMs without big ports, or those that are not designed like small bullets--I can never get them to fit right, and without the port, I can hear my breathing too much--makes me feel like I'm under water.Try the final audio design A8000
E500 thenI'd never spend that kind of money on any headphones ($2,000). If I was going to buy a TOTL IEM, I'd probably buy the latest Flare as it too uses a Berilyum driver and most reviewers believe it is better than Campfire's offerings. Also, I don't like IEMs without big ports, or those that are not designed like small bullets--I can never get them to fit right, and without the port, I can hear my breathing too much--makes me feel like I'm under water.
With regards to the Final Audio E2000 that I just received: I have to burn them in, but what I'm hearing is quite good for $40 though there is WAAAAAAYYYY too much bass currently. Hope it settles down. Also, the soundstage isn't bad for an IEM, but it does not come even close to my Shozy BK in soundstage or separation (separation issues is likely do to the overbearing midbass).
E500 then
