Willber
As an all-rounder, no (but it's close). For purely acoustic and vocal music I would just edge towards the SR2.so sr2 16ohm over fengru silvers?
The red is quite bright (I love it) but nothing compare to my orange Kube.Wimp!
Me neither, and I'm willing to take the risk. That red cable is rather vibrant - I think it would draw too much attention and I'd get robbed lol.
Ordered!
SR2 - lots of burn-in required.
@jogawag, have a word with him!I will be the judge of that!
Red is the reason I bought my Willsound MK1 rev 2 over a year ago. Don't be afraid of color!
I have a problem with my ME80.
There is an imbalance between left and right which affects the quality of the sound (not just the volume).
The last time I used them, I noticed that if I covered the rear vent hole on the RH bud the sound changed, as you would expect. However, this change doesn't occur when I cover the LH vent.
I concluded that the LH vent was blocked in some way, but poking around with a needle hasn't changed it.
Does anyone know how to get inside the shell so I can take a look?
Thanks, but I don't know how to get into it...We had this case in russian forum. The one who had such issue opened up me80 and discovered that the driver in wrong ear turned by 90 degree of what it is is supposed to be. Very probably,that you have the same case or similar - driver is not positioned correctly. Also,probably,you guys are not the only one...
SR2 16ohm requires 50-100 hours of burn-in to get enough bass.I will be the judge of that!
And soundstage IME.SR2 16ohm requires 50-100 hours of burn-in to get enough bass.
The soundstage of SR2 sounds wide enough for me.And soundstage IME.
And me but it took time to open out.The soundstage of SR2 sounds wide enough for me.
