DBaldock9
I finally did a comparison of my three more expensive VE earbuds (not including any of the Monk+).
They're setup like this -
Asura 2.0 (2017) - Stock 2.5mm TRRS cable, VE Rubber Rings
Asura 2.0s AOE - VE Pure Blue 4-Strand 2.5mm TRRS cable, VE Rubber Rings
Zen 2.0 ZOE - Oyaide 102ssc 2.5mm TRRS cable, VE Rubber Rings
Running the stock Onkyo Music Player app on my Onkyo DP-X1 DAP, and using the Balanced 2.5mm TRRS output - I'm looping on some 24-Bit/192-KHz High Res tracks from the Chesky Records Ultimate Headphone Demonstration (2014) album. I'm using my ears to Level Match the volume when switching earbuds, rather than any test instruments - so some perceptions could be colored by that, as well as small differences in cables.
The AOE and Asura 2.0 sound very similar, but the AOE may have a bit more Midrange, which results in a slightly closer / shallower Sound Stage.
The ZOE has more Bass & Mid-Bass than the AOE or Asura 2.0, and its Sound Stage is closer / shallower than theirs.
Treble (level)
AOE => Asura 2.0 > ZOE
Midrange (level)
AOE > Asura 2.0 > ZOE
Mid-Bass
ZOE > Asura 2.0 => AOE
Bass (level)
ZOE > Asura 2.0 > AOE
Sound Stage Width
Asura 2.0 > AOE > ZOE
Sound Stage Depth
EDIT: NOTE - Aside from the additional Bass that the ZOE has, and the more forward Midrange of the Asuras, there's not a large amount of difference between the three earbuds.
Treble (level)
Midrange (level)
Mid-Bass
Bass (level)
Sound Stage Width
Sound Stage Depth
