Unex
- Oct 12, 2013
Fast engrish review of Monk Lite 40ohm and 120ohm ver.
Source: Hidisz AP100
Music: Different from sympho metal to acoustic and PoP.
In short, the first monks are better. 40 ohm version with a mudy bass, 120 ohms less mudy, but in general sound signature is the same - recessed trebles, weak mids and mid-bass domination.
Bad with multi-instrumental, fast music. Acceptable under PoP, acoustics, something where there are few instruments and / or its artificialy generated electronic sound.
As example :
Lindsey Stirling, Diablo Swing Orchestra, Katzenjammer sounds acceptable. (but they sound good on anything, lol)
In general, for a few dollars, to use with a smartphone - Ok. Just dont try to find something what laid behind more expensive earbuds.
SPC version comes in a box with earbuds and a hard case, beautifully packed - you can easily gift it. But there are no clothespins, and it's sad.
As example :
