Oct 16, 2017 at 10:21 AM Post #23,809 of 80,695
Nope. Heard a lot people spelled positive things about them. Guess I would just give the Graphene a try with stock full foam to increase the bass if they are comparable with Svara L. Plus, I can get Edimun with price more cheaper than Svara L.
what foams are you using with the graphenes? i can only use them with full foams. The svara's bass is bigger than the graphenes with full foams
Oct 16, 2017 at 10:30 AM Post #23,811 of 80,695
I read graphenes are pretty close to Shozy BK
if one would want to go ToTL sound with mid fi price is it possible ? Any suggestion . Looking for good bass and soundstage
I dont think the graphenes are close to Shozy BK. Ive them both and the BK is miles better.
Oct 16, 2017 at 10:31 AM Post #23,812 of 80,695
What if I have graphenes on hand? Will it still be a significant upgrade?
graphenes and the vx pro? i personally like the graphenes more
Oct 16, 2017 at 10:48 AM Post #23,813 of 80,695
Odd question but could you compare both through a mobile source? I'd love to know if there's enough of a difference for me to buy the shozy stardust if I'm going to be using it through an iphone 6s mostly.
Oct 16, 2017 at 10:51 AM Post #23,814 of 80,695
Ill try later but Im not using an Iphone. Ill have a listen off my Samsung S8+
Oct 16, 2017 at 3:31 PM Post #23,816 of 80,695
nope, the graphene's bass is enormous in earbuds standard. in my collection the ones that comparable in bass are the vidos, willsound mk2, and the svara L.
have you tried the svara?
But compared to the vidos, I find the bass of the graphenes much cleaner, detailed and controlled.
I'll have to try full foams on them (so far I have been enjoying the donut foams on them)
Oct 17, 2017 at 5:22 AM Post #23,817 of 80,695
I have received NiceHCK Panda PK2S.
Now, I will compare four of taobao Cresyn DIY Docomo PK2(CPK2) / NiceHCK DIY MX500 PK2(MPK2) / NiceHCK Panda PK2S(PK2S) / Yuin PK3(PK3).
Bass: PK2S>CPK2>MPK2>PK3
Mid: PK2S=MPK2=CPK2=PK3
Treble: PK2S=MPK2>CPK2>PK3
Cost Performance: CPK2>=MPK2>PK2S>PK3 (CPK2 is only $5.)
If I need to choose one , I would choose the PK2S, because of stronger bass(not need dounuts) and smooth cable and pretty panda design.:ksc75smile:
Edit:
I used review pattern of Mr. CharlesRievone.
