Try blow air in the shell. Maybe it's an hair or dust that came in
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
theoutsider
I have the same problem with my Moondrop Nameless :/I was listening to the K's k's 300 Samsara last night for the second time, and noticed a rattle on the left side when moving around. Sounds like the driver is rattling around. Returns to China are expensive and generally not worth the hassle...... is there any way to fix this? Thank you.
Yeah, this is a very common issue with so many earbuds, I've had it with Vidos and EMX500. I've tried many many things but one thing ended up fixing it for both. Also, keep in mind that my EMX had rattling so much that it started to make all kinds of different 'something is very wrong' noises.
The thing that fixed it was this: open them up (these front covers are usually easy to open, EMX had a lot of glue but it was manageable in the end), be careful not to damage the membrane if the speaker fully pops out of front cover as membrane isn't fixed to the rest of the driver. Once it's open, look at the driver, there should be some sticky slimy glue holding it a bit in place, carefully scrape it off with a knife and then you can pull the driver out. Once it's out, locate the thin coil wires going to the membrane, this is the only thing that you need to protect, and obviously don't do anything to the membrane itself, other than what I did. Now it's time to start moving the membrane holding it by it's sides, try to separate it from the rest of the driver, just a little and obviously the part where coil wires are must remain close to each other. With my pair, there was some glue very close to coil wires between membrane and rest of the driver, and it wasn't supposed to be there. Once you separate them nicely so that you know that this kind of glue is no longer active, it's time to slightly shift the membrane, twist it. It has very little wiggle room due to coil wires being short and fragile, but just enough can be done. Put everything together and test it.
I had to open my emx about 30 times before I fixed it, twisting the membrane a bit ended up being the thing that worked, and it did instantly (twisting it compared to the rest of the driver, perhaps if the coil wires aren't exactly where they should be, they end up pulling on the membrane, it's just a wild guess).
One more thing, I've never opened earbuds before and was a complete noob to anything DIY audio wise, although it looks kinda scary, it's really simple and I didn't damage anything even on my first try. Here is a photo that I posted a couple months ago that might be useful.
On this driver, and they are all so very similar in shape and components, gently hold this yellow ring and pull it up, angling it towards the V cutout where the coil wires are, and after all of the glue is gone, every so slightly twist it and put it back.
golov17
sagor1
K's Earphone K300 300ohm earphone.
Now i have question.
https://imgur.com/a/BtXNZ
1.What is that thing i marked on the picture?
2.I see there is a 2kind of foam 1 was cutout in both side & other one is just regular.Why 2types?
theoutsider
Lol, your Mojito is a very expensive version of EMX500.likewise with my Mojito
I read that Rose Tech operated with only 10 employees in 2016. That includes 2 designers and 5 technicians. The owner himself doubles as the customer service rep.
Dear god, I could understand this rattling issues with cheaper earbuds, but Mojito... Can it even be opened properly? Does one possess the courage to even think about trying to fix it? So many hard questions, hopefully no one will ever have to answer them, and for the ones that do, our thoughts and prayers are with you!
I just ordered the
You have a choice of sound, either full foam or donut foam
golov17
I sent them for repair to China, but the fact is that the warranty in 1 year has already passed, so I'm not sure about the result ..Dear god, I could understand this rattling issues with cheaper earbuds, but Mojito... Can it even be opened properly? Does one possess the courage to even think about trying to fix it? So many hard questions, hopefully no one will ever have to answer them, and for the ones that do, our thoughts and prayers are with you!
theoutsider
You are not alone. The official Rose Tech forum on Baidu is plagued by complaints about their QC. Some of them sent in their buds for repairs as well.I sent them for repair to China, but the fact is that the warranty in 1 year has already passed, so I'm not sure about the result ..
golov17
at least my two pairs of Masya are still in working orderYou are not alone. The official Rose Tech forum on Baidu is plagued by complaints about their QC. Some of them sent in their buds for repairs as well.
Perhaps it is a problem due to the QC of fragility of 2 Pin part of Rose Mojito? I am concerned about my Mojito...You are not alone. The official Rose Tech forum on Baidu is plagued by complaints about their QC. Some of them sent in their buds for repairs as well.
theoutsider
So 3 pairs of your Rose-buds are in Sichuan (Szechuan) now?at least my two pairs of Masya are still in working order
theoutsider
Ya, apparently the 2 pins sockets are the weakest links.Perhaps it is a problem due to the QC of fragility of 2 Pin part of Rose Mojito? I am concerned about my Mojito...
golov17
No, problem with bass driverPerhaps it is a problem due to the QC of fragility of 2 Pin part of Rose Mojito? I am concerned about my Mojito...
Total: 43 (members: 8, guests: 35)
