Earbuds Round-Up
Jun 14, 2017 at 8:40 AM Post #20,746 of 75,470
Would you consider the LE Cygnus a big and worthwhile upgrade ( I listen to mostly R&B and pop music) from the original Cygnus ? I love the original one but found the BK to neutral for my tastes....
Original Cygnus is already really good, thus doubling the price for Cygnus LE will not give you double the SQ. In that sense, I'll say no, it is not by any measure a 'big' upgrade. Besides, as I have said, the sound signature on Cygnus LE is quite different from Cygnus and BK, so there isn't a 'direct upgrade' either, you will probably have to listen for yourself to know whether this new sound is for you or not.
Jun 14, 2017 at 9:18 AM Post #20,748 of 75,470
Thanks, your post makes perfect sense.
Jun 14, 2017 at 9:21 AM Post #20,749 of 75,470
Jun 14, 2017 at 10:38 AM Post #20,751 of 75,470
Thanks! I didn't realize it was the NICEHCK DIY PK2. Thought it was something else.
I have two versions, of the Nicehck DIY PK2, the black cable and original white shell. They sound identical but I can do an AB test if anyone's intersted.
So much for the Cygnus using NOS (new old stock) drivers. Appears to just be marketing. Big thanks to @golov for sharing the driver photos and listening experience.
Between the DIY PK2 and the EB200, Nicehck is on a roll!!!
Jun 14, 2017 at 5:17 PM Post #20,753 of 75,470
Got my CAX Black in today! Now starts the long burn in process. But wow, the cable is crazy stiff. Got a neat Cypherus box though.
My CampFred 2 buds just shipped as well. Hopefully no delays for that one.
Jun 14, 2017 at 6:09 PM Post #20,754 of 75,470
Again, my Vido still requires a bit more burn-in. But as far as initial impression goes, it is surprisingly similar to the original Sennheiser MX500 in tuning, but overall seems to be a bit better as well. Pretty solid entry level earbuds as far as I concerned.
No. My preference is Stardust > Zen 2.0 > HP-650.
Not agreed. Sennheiser MX500 sounds thinner and less powerful vs Vido. Vido has fuller bass and midrange and has better detail retrieval. At least mine doesn't have similarities with MX500 except shell. :wink:
Are you using it naked or with foams @ClieOS ?
Jun 14, 2017 at 8:55 PM Post #20,757 of 75,470
Both with foam, and I measured the frequency response on both to make sure it isn't just in my head.
Jun 14, 2017 at 9:20 PM Post #20,758 of 75,470
I quite like the Rose Masya in that price range. Your mileage always varies, depending on what type of music and signature you prefer.
Thanks for your input! I like a warmer sound signature that isn't too analytical or cold. I do however love hearing little details in the highs but I do prefer to have a slightly warmer sound. Mids cannot be recessed too much and I want at least some sub and mid bass.
Is the Masya better than the Zen or Stardust? Maybe @ClieOS could chime in? Cheers
Jun 14, 2017 at 9:30 PM Post #20,759 of 75,470
@golov17
I saw in an old post of yours from 2015 that you recabled a pair of mx980's. I would like to do the same. Do you have any advice you could offer on opening up these shells without damaging anything? Thanks.
No, just be careful, good luck
Jun 14, 2017 at 10:14 PM Post #20,760 of 75,470
I forgot what the model number for it is and it is no longer in my aliexpress history, but it looks identical to the AWK-F32S (zen 1 cable and aesthetic). I called it the V1 because I know at the time of purchasing it was the first Seahf 32 ohm bud with that look. So I'd say it is the AWK-F32S, unless they made more than one 32 ohm bud with the zen 1 cable and white housing. Here is a link.
Thanks a lot @slappypete
