teesui
- Oct 8, 2016
What about the Qian39?
Also, the SHE3800 seems to have good reviews on here.
How much do you love the Monk+ sound signature? If you make it massively more detailed and transparent, remove the upper midrange weirdness, otherwise leave the Monk+ sound sig intact the Seahf 650 is a better option than TY high ohm or yinman which is more in line with the She3800 than anything.
How does you compare it with SHE3800? Or may be with Monk+/ EM3 etc. Also, does it come with Mic?
Just ordered a couple of Qian39 for mods, the Yinman150 and K300 with some foams and tri flanged tips for my Hi905.
Just wondering if the Walnut has enough power to drive both the Yinman and K300 otherwise i might have to look for a dedicated amp.
Edit: I read flamesofarctica paired the K300 with the Walnut and Xduoo X3 + FiiO A3. Hence sir if u could let me know if ur nut has enough juice to power the K300? I hope mine does (pun intended lol)
Pretty excited to know how both sound like as the highest impedence bud i have now is the K64. And am out of town for a week with no time for music T.T
Is Yinman 600 hard to drive?
After long wait I finally got my qian25. Avoid SUNYOU shipping. Took over a month to arrive to Malaysia. while normal China post small packet only took 10 days.
OOTB with supplied stick foam it sound almost like monk + with better clarity. big sound and hard hitting bass.
One basic question. Seems my SHE3800 is also broken as I am hearing some noise on right side. Same happened with one of the unknown earbuds (https://www.aliexpress.com/snapshot/8288643060.html?orderId=79548978380002&productId=32674311412 ) which were very good with good soundstage and very good bass. They were broken too after 2 months or so.
My question is, if I am using PowerrAmp and using these buds which are 16 or 32 Ohms, is it possible that they are broke down due to PowerAmp? Shall we use 64 Ohms or more earbuds for PowerAmp as nothing happened to Monk+ even till today as that is 64 Ohms. Pls suggest. As of now, I am stopping using SHE3800 with PowerAmp. As that is broken, I will now need same or better soundstage, warmness and bassy earbud (but with Mic) to use with PowerAmp. So will need your suggestion again :|
Is anyone using PowerAmp os experienced this earlier with any other AMP Player or device?
So if the above is true and we cannot use low impedence buds with AMPs, then I will need to buy something else which has sound signature like SHE3800 or even better but Monk+ does not fit in my ear properly and come out in every now and then so I will need something which has slightly smaller speakers but much bigger in terms of Bass and Warmness. I would also prefer if something with Flat cable is there. Monk+ cable tangles too much. Also, my budget is not high as always so suggest what is the best option (or options) for me?
Looks like FiiO EM3 has impedence of 47 Ohms. Seems that will be good in terms of Bass + Warmness and also with Mic and they looks good too. I really don't remember how they were sounding before I returned to them after listening with iPod 7G + Samsung Phone without PowerAmp. I guess they should sound good with PowerAmp. What is your suggestion? Or any better option?
