Shaffer
- Sep 7, 2013
Can't really think of any other all-tube 300B headphone amps at the WA5 price point aside from Eddie Current offerings. If you're willing to go with a purely speaker amp and build a Robinette box your options increase. And of course there are hobbyist amp builders out there. But let's be realistic. If you're buying a 300B amp you are also realistically committing to buying a couple thousand in tubes to make the most of your purchase... or you would have been better off with an amp that uses cheaper tubes. Throw in the cost of TOTL headphones and a thousand bucks in either direction starts to look like chump change.
Here's my problem, well, one of them, with the WA5: It's a component surrounded by what looks like superb build quality, yet the attention to detail is lacking. For example, the transformers are simply covered by aluminum extrusions; they are not potted. Why not? Why are the transformers not potted? It's not as if it's terribly difficult to do. This seems to be a part of their business model - build a product that looks great and then use it as a substrate for upgrades that can cost more than the amp, itself. Why not offer an amplifier that can stand on its own? The WA6 certainly can't. In semi-stock form it doesn't sound any better than a DV336SE, in some ways worse at 3X the price. I have them sitting next to each other. Dump another ~$150 into the WA6 and it becomes more competitive. Introduce a Feliks Elise and the game is over, but I digress. I have no doubt that the WA5 sounds significantly better than my WA6. It better....
