So far I've stuck with stock-fit tubes. My other amps run 6SN7 drivers and I'd rather play with something different.
In essence, the only tube that has not introduced a buzzing sound is a RCA 6EW7 fat bottle. I have all other varieties of stock-fit tubes, some from different manufacturers. Mostly, Sylvania and GE. I also have 4 pairs that I inherited with the amp: TS, GE, and a Pinnacle. All buzz. FWIW, I have a GZ34, a Brimar, a JAN 1641, and a bunch of other rectifiers. Still, only one pair of bottles is silent. I'm not thrilled.
Sorry to hear about your misfortune with the noisy tubes, or amp with these tubes.
The only power/driver tubes that buzz in my WA6 are the NU-6F8G's (which I thought I fixed with Deoxit) otherwise all of my other tubes are dead silent. [size=x-small]Right now I'm unfortunately in the process of eliminating either bad power/driver tubes or the rectifier tube in my WA6. I'm getting heavy static/failure in the left driver of my HP's, and I've already eliminated the HP's by switching them and still had the issue. Then I switched the power/driver tubes and still had the issue[/size]…[size=x-small]now I just changed the rectifier, so I'll see what happens…I hope its not the amp, but I do believe it is my UE-596 that is bad. [/size]
