ericj
- Aug 2, 2005
the iFrogz pads saw some iFrogz Toxix ones today and they are much shallower than the ones I am using now, might go back to the store and get them, but a bit pricy as a donor simply for pads, still, but as we all know pads can make or break a thing and they seem as shallow as the YHE ones anyhow.
Thanks for the reminder. Then I can use the shell possibly, maybe.
Yeah, Found my blue toxix pads today. They look like they will do a pretty reasonable job, either doubletaped on or with the flange wrapped around the whole pod (perhaps with the cable run through a hole punched in the flange).
Think I'll spring for this set of black pads: http://www.amazon.com/EarPollution-Toxix-Headphones-Gold-EP-TX-GOLD/dp/B001EP86K6
Also i've been thinking about maybe re-stuffing the original pads with a donut of memory foam - trick is, where to get a thin sheet of viscoelastic foam? maybe a set of "as seen on tv" memory foam insoles. Might be too dense tho.
