dtmhtk
- Apr 3, 2013
You still need a green and a yellow one to complete the rainbow.
I do my own impressions now. All it takes is two tubs of impression goo, some dams, and a syringe. Cost per impression is probably $2 or so. I screw up sometimes but it takes maybe 5-10 mins to do one so they're easy to re-do.
Better pic:
Hmm... that sounds very odd to me. Not sure how it would work and even if it did what the benefit would be in crossing over a signal before feeding it to the (single) driver.
Sounds like it might be a case of "lost in translation" like Fischer Audio advertising their SBA-03 as "dual armature" at first before elaborating that it's actually 1 per side / 2 total.
you should start a new photography style, "CIEM art"
Man this is really outstanding work you've done!
However ECCI has intruduced the pr100mkii, pr200mkii last year and pr3002 this year, which are the newer version of pr100/200/300.
Waiting for your review :3
Big thanks for the JVC FXT90 suggestion Joker - picked them up for $89 on Amazon and they arrived yesterday. Signature and fit are just what I was looking for! I can stop looking...until the inevitable upgrade, anyway...
Joker,
I see you are in Santa Monica - would you do mine for a 6 pack of imported beer and a Monoprice 9927? (I'm only half-kidding)
Is that a perfect log spiral?
I am not a licensed audiologist, so while I am happy to do my own impressions, I don't think it would be safe for me to do someone else's. A few of the hearing professionals I've talked to had horror stories to share about impressions gone wrong. I have a pretty good feel for what I'm doing when it's in my own ear but that's the extent of my confidence.
joker, which UE double-flanges are compatible with HA-FX40? I saw you mentioned them in the preferred tips field but I don't know which one exactly.
Edit: I think I found them on amazon, are they UE 600vi?
Joker,
there are lots of ear buds that comes with the Vsonic GR07.. I've found the hybrid to be the most comfortable.. but there's a problem in the form of my ears.. my left ear has more inner bone than my right ear which lets me fit the GR07 right earphone easily while I haven't found any comfortable position for my swiveling GR07 for my left ear.. I think because of the greater inner bone, the opening in my left ear is a little smaller than the right.. I'm asking if there is any more ear bud pair that I can use to fit both my ears perfectly? I find the bass on my left ear lacking because of the wrong insertion.. and the noise isolation is also reduced because of that.. I don't have a problem with the body of the earphones just the ear tips.. I hope you understand what I'm saying here..
would you think that comply foam tips would solve my problem here? or is there any other you'd recommend? I wouldn't like to go for customized ear tips because of its swiveling function.. I do think I wouldn't need it that much.. But still I enjoy mo GR07 and think it'd last for a long time..
No worries, I was half joking - I did find out one nice thing - I spoke to an Heir Audio representative and they offer free impressions if you can find your way to San Diego - in fact, they like to do it because many audiologists are used to hearing aid molds and there is a difference. Of course, you have to be buying an Heir Audio product.
Thanks anyway!
If balanced armature technology is being used in IEM,
could we be seeing it in other speaker formats such as on-ear or
bookshelf loudspeakers???
Ljoker how would you compare RE-400 and DBA02 / Brainwavz B2?
RE-400 should have better low-end.
