EPICFAILXD
- Mar 2, 2012
Haven't heard RE400, but the IE800 sounds amazing. If you're in HK, then the TDK's are probably cheaper and are (IMO) the ones you should buy. However, as an all rounder (build, comfort etc) the RE400 would be a much better choice.
Hi all
So from what I read the HiFiMan RE 400 is rated pretty highly around here.
You guys reckon, if for the same price I can get TDK IE 800. Which one would you choose?
I listen to all range of musics but mainly EDM and pop jazz and a bit of rock and hip hop. I want mainly the clarity really in my IEM.
Cheers
