- Mar 20, 2010
Oh, well, I only liked it for bass neutral cans like the PC360, Q701, HD598.
In my experience the mixamp's boost is one that leans towards affecting the low mids. This may be a sloppier bass boost then some tighter ones that boost more specific lows with stronger punch/slam, but a broader boomier bass boost does sometimes give off a home-theatery bass effect. Or at least it can make the overall sound fuller at the expense of a bit looser sounding low end. The bass boost on the DSS is tighter and affects fewer frequencies with stronger slam, but doesn't fill out the sound much.
That will definitely be end game for me.
Sure it will. I believe you...
Trust me, for the power it has... there is absolutely no reason to feel like I need an upgrade. This is the most expensive Audio piece I have decided to go with. I trust Audio-GD's stuff. It was between this and the Compass-2, but I felt that this would definitely not make me wanna upgrade, while the Compass-2 was more for tweakers.
Gonna have to pair it up with the ODAC to keep my sanity. Once it's all set, I'll sell the E17.
evshrug said:I remember you thought you might need the portable DAC of the E17, is that no longer the case?
