Magnus_CA
- Sep 2, 2007
If I plan to run the Beyerdynamic DT 990 off a console controller, is the only logical model the 32 ohm?
So my friend tested the range earlier today and between 2 walls and it was stable up to about 30feet. So I think with common sense, you can expect a pretty darn good range for a setup like yours. So if your transmitter is like in the middle of the home you're in, you should be perfectly fine anywhere in the house.My main use case for the iFi might be different than most, but my PS5 setup would be:
Creative GC7 > 3.5mm to BT transmitter > BT to iFi Go Blu
Modmic wireless, headphone of choice
This is so I can transmit SXFI. I have tried the SXFI Theater headset from Creative, and the SXFI effect is subtle compared to what you get with the SXFI amp or GC7.
I've been using the BTR3K for this, and it works ok but as I mentioned more power would be nice.
When you review it, if you could touch on the range and BT stability, I'd appreciate it.
Double processes it. You should only use one.I know MLE is a big fan of virtual surround sound, but I have question that I have not been able to find info on. When using Atmos, Sonic, Wave, Redscape, or Sony Tempest at the system level (PC, XBSX, PS5) should a game that has 3D or SS in their audio tab be off or on? Does it work in conduction with system setting or double process it? Thanks for any help! Driving me nuts LOL
Choose whichever sounds best for you, but yeah, don't use system level and game level audio options together. One or the other.I know MLE is a big fan of virtual surround sound, but I have question that I have not been able to find info on. When using Atmos, Sonic, Wave, Redscape, or Sony Tempest at the system level (PC, XBSX, PS5) should a game that has 3D or SS in their audio tab be off or on? Does it work in conduction with system setting or double process it? Thanks for any help! Driving me nuts LOL
You should just test it yourself. It'll be easy to tell if it's double processing.Guardians of the Galaxy is the only game i can think of that’s has a Dolby Atmos in game option under audio. I have to double check. I assume it’s fine to keep Atmos on the XsX at the OS level as well?
Thank you both so much for your responses! LEGENDSChoose whichever sounds best for you, but yeah, don't use system level and game level audio options together. One or the other.
