mac0172
In combination with a blue tooth adapter?Tempest 3D audio works ok or not at all on a game by game basis. I'd definitely look into an alternative if you have options. Like the X7/G6/GC7, etc.
Hi, MLE & other ps5 owners.
May I ask a question here?
At the moment I use a ps5 - hdmi optic adapter- astro mixamp- pc38x with virtual surround on and without tempest 3d. because of all the wires I play on a monitor. Now im gonna move to a new house in a couple a weeks and bought a 120 fps-4k tv so I'm propably gonna be gaming on a tv and will be playing with my pc38x directly in the controller with tempest 3d on. I already tested this (the 5 profiles on ps5) on cod vanguard & warzone but directional sound(footsteps etc) is so bad compared to my mentioned setup. Does anyone tried both and recognise this? And or has any advice?
Thnx!
Whoa between Pro and KSC75? sounds perfect! Hope these launch in Europe soonJust look at my KSC35/Sportapro review on the first page. They'll essentially perform the same.
As far as I'm concerned, the KPH40 would be the easiest recommendation for me for any purpose (not headset) under $100, and my absolute go to as a secondary or tertiary headphone to compliment your big boy headphones. I would never live without it.
Since the KPH40 exists now, I'd replace the PortaPro/SportaPro in the hierarchy, mainly because the KPH40 headband is just better, period. Howver, as I'm not someone who'd use the headband, I'd take whatever is cheapest and attach KSC75 clips to them (personally speaking). Right now, they're all so close in price, I'd just get the KPH40 for the newer driver cover. edit: I see the SportaPro is $22 right now, which is CONSIDERABLY cheaper than the others at the moment, and I'd GREATLY recommend you get those if you already have a headband or clips, as the Sporta are just PortaPros with a crappier headband, which you can just take the drivers and attach to any clips or other higher end headbands.
I've long been a Koss 60ohm driver fanboy, and that remains.
Maybe I should do a Koss 2021 Review Update
KPH30i don't make sense these days, now with the KPH40 out.
edit: Trying to compare the KPH40 on KSC75 clips, with KSC35/PortaPro on KSC75 clips... I CAN hear a difference. The KPH40 drivers seem to split the difference between the brighter/dryer sound of the KSC75, and the bassier, smoother, darker sound of the PortaPro/KSC35. Interesting. Let me compare the other PortaPro I have to it, to see if it holds true.
Ok so yeah, the KPH40 = more neutral, not as bassy as Porta/35 drivers. This has the effect of pushing the vocals out more. It's good, though I kinda like the more bombastic bass on the Porta/35 drivers. Not sure I'd choose these over a Sportapro/Portapro driver, but these are amazing times for Koss fans. These are likely going to be the new king overall.
I'd say it def falls outside of driver variation, as my Porta and 35 sound identical, and these just don't sound like those.
That is...unless Koss has updated all of them to these new drivers. Who knows...
Yeah. However, it can also be that Koss updated the PoprtaPro/KSC 35, Sporta driver and is using that new version for the KPH40. The reason I say this is because the new PortaPro utility LOOKS like it has the same housing as the KPH40, so it could presumably be the same, and they don't use the drivers from before. However, to ensure you get the new driver, get the KPH40.Whoa between Pro and KSC75? sounds perfect! Hope these launch in Europe soon
I received my KPH40 yesterday just in time since it’s not available on Amazon at the moment. Now I see what all the fuss is about. Tested them out on some music and these little headphones are truly marvelous! Going to try them out on the PS5 plugged into the controller next. Thanks so much for the recommendation.Yeah, I'd look into the Creative BT-W3.
Hey guys what are the best headphones for gaming in the $500-1500 price range? Closed or open doesn't really matter. Is HD800/HD800s the endgame / holy grail for gaming? I am interested in semi-competitive FPS and mostly for the soundstage, positional accuracy and for 3D sound
Thats a huge spending range.Hey guys what are the best headphones for gaming in the $500-1500 price range? Closed or open doesn't really matter. Is HD800/HD800s the endgame / holy grail for gaming? I am interested in semi-competitive FPS and mostly for the soundstage, positional accuracy and for 3D sound
I'd put my Monolith M1570 up against the HD-800S anyday.If you don't mind spending the money, get an HD800S and call it a day. You will always be wondering what you're missing out on if you don't.
- Audioquest Nighthawkam looking for a headphone that gives me good immersion for single player games, not trebblefocused competitive games.
Just in case you wondered what the point of the USB Bluetooth dongle was… the X7 is not compatible with the PlayStation USB. However, the X7 is very, very versatile. Since it can play audio from multiple sources at once, what you do is use the Bluetooth for chat audio, the optical for game audio (make sure both your console and TV/optical extractor are set to passthrough the Dolby bitstream), and then you will hear everything and you can plug your mic into the port on front of the X7 (or use the X7’s built-in mic… which is just ok).In combination with a blue tooth adapter?
HD 800(S) with gaming is a unique experience. It sounds hyper realistic rather than entertaining, and the incisive resolution and detail really do just make things easy to hear. It’s an edge-of-your-seat presentation that really grabs your attention, and it has low distortion.If it's competitive - HD800s from what others have told me. If you want immersion and to feel explosions etc, go with the Fostex TH900 or 909.
Hmm, haven’t heard those new Beyer’s yet.Thats a huge spending range.
If you don't feel the need to spend the money you can get great sounding headphones for a lot less that are great in games. I bought a pair of 990 Pro's on sale a few months ago and my HD800S grew cobwebs on them after. (Literally, I picked then up and there were spiderwebs in them). They're super fun if you like a more v-shaped sound (I do in games especially). Easy to drive. Great soundstage and I was really impressed with their imaging. Super accurate. MLE has a review of them on the first page. Treble is a real thing on these cans but for "competitive" FPS soundwhoring that can actually come in handy. But unlike the HD800S you don't need any EQ if you want some more "fun" elevated bass either.
I really like them, I feel like they're a fantastic performer for their price range (especially on sale).
