- Mar 20, 2010
Nice review. Enjoy your new gear! Looks really nice in your setup too. And please don't worry about it. Anyone's input especially with new gear is welcome.
I like how you talked yourself into getting them.
https://koss.com/products/kph40-utility
Koss Finally did it.
No longer do you need to source the KSC75 or PortaPro driver and get a Parts Express or Koss Retrospekt headband separately.
Took them THIS long to finally do it themselves.
Granted, they are still using the utterly terrible cable that will absolutely, without question break on you instead of having MMCX connectors, but hey, maybe in 2 more decades Koss will get around to having a detachable cable.
This ain't for me, since I prefer clips, but I know a lot of you would want this. The drivers look detachable like the 75, 35, Porta, Sporta, so I COULD use them with clips if I didn't already have two modded PortaPros.
Ah damn it. I'm gonna get them for my mother. I'll review them too. Once they come back in stock anyways.
Lol, I mean, I'd never actually use them as they come. I'd have to get them modded with MMCX cables and find myself another set of KSC75 clips, which I dunno if I have any fresh ones.I like how you talked yourself into getting them.
So I have been looking at the info for the carrier, sadly doesn't look promising that the SXFI-out port will allow use of our own gear with SXFI, based on info from Creative's site:The new SXFI Carrier (their SXFI enabled Atmos soundbar) has a USB-out which some reviews say is "SXFI enabled", and it is even labeled on the device as an "SXFI Out" port. But there is no further explanation other than it is designed to be used with their wireless dongle.
All the reviews utilize that USB out for the USB Theater wireless headphones....but I wonder if the USB-out actually just feeds SXFI out to anything that takes USB audio?? If so this would be the first thing that has SXFi out of any type. Sadly it is $1000, and as a soundbar it is not exactly easy to just incorporate it into your desktop PC audio setup, so this won't be one of my impulse purchases anytime soon.
It is nonetheless interesting as it claims Atmos capability with SXFI, which would be new (if it was actually virtualizing an Atmos room). It also decodes DD+ from consoles, so since it has HDMI in/out it would actually work perfectly in a living room setup with a console. No need for optical splitters or routing audio through your TV optical out which is needed for the GC7.
As the PC38X is very easy to drive, and you can do with a headset capable dac/amp, I'd say the G6 or the Fulla 4. I don't think you need to spend for the Hel 2. In the case of a secondary device, I think the Fulla 4's simplicity works out better than the Hel 2, and it doesn't need to be powered externally.@Mad Lust Envy
I have the PC38X with my PS5, currently using a UAC1 DAC to Topping E30 to Topping L30. I switch between the 38X and IEMs and use a ModMic. I was thinking on getting something simpler that I could use with the PS5 so I can use the 38X mic (if I'm lazy or the ModMic dies).
What would your top 3 recommendations be? I'm leaning towards the Hel 2, but not sure I want to spend $200 on a "backup" device. Thanks in advance.
Excellent. Thank you for the reply.As the PC38X is very easy to drive, and you can do with a headset capable dac/amp, I'd say the G6 or the Fulla 4. I don't think you need to spend for the Hel 2. In the case of a secondary device, I think the Fulla 4's simplicity works out better than the Hel 2, and it doesn't need to be powered externally.
Creative G6 or Fulla 4 are my recommends.
The G6 is feature packed, and the Fulla 4 is polar opposite, being super simplistic. So go with which one appeals to you more.
3rd? Can't say I have a 3rd. Hel 2, but you already know about that one.
I see it on Amazon for $170; the gray one is over $200.I didn't realize that G6 is MORE expensive than even the Hel 2 now.
What is 2021?
