- Mar 20, 2010
Ok, to sum up:
PS5 solutions for now.
1. Penrose is amazing for ps5
2. USB C to 3.5mm dongle works, but too much static and not enough juice even with amp desktop amp attached.
3. Asus Xonar U3 works. Decent for easy to drive headphones like the PortaPro. Can attach dac or amp for more power, still not ideal for anything that is harder to drive.
4. Schiit Hel and Schiit Modi 3 usb functions do NOT work. Hel can be used in amp mode for the U3 or G6 but not powerful enough.
5. Creative G6 works well but needs to be high gain, and maxed out to get moderate volume for something like a 6XX. Ideally, you WILL need a desktop amp for the G6 of at least Magni 3 level or MORE.
6. Best solution I have atm is Creative G6 - optical out - optical input of a DAC like the Modi 3 to Magni 3 in high gain at 3 o clock on the volume knob. Nearly maxed out, so not much headroom.
Asgard 3 or Lyr 3 are sounding like really good ideas for amps to use with the PS5.
At leastil until and IF/WHEN Sony decides to update the ps5 to allow 3D audio to be piped through the HDMI out, then compatibility will rise exponentially.
