PurpleAngel
Soundmagic (32-Ohm) HP200 headphones, like an improved DT990.If I wanted a headset that's good for competitive gaming but also makes listening to music a pleasure, should I look no further than the Beyerdynamic DT990s or the Philips X2s?
Also, in the rating you've given to the Beyerdynamic DT990, do you also mean to include the 250 ohm ones?
Sorry for asking this question if it's dumb, and thanks. xD
What is your budget for a DAC/amp?Thanks for the reply. Which amp would you recommend to pair the DT880s or DT990s with for total beginners?
Also, have you ever tried the Anker Soundcore Vortex headphones? And what about the Massdrop x Sennheiser HD 58X? If you have, how would you rate them?
I do like my HD58X headphones, use them everyday.
I own the DT880 (250-Ohm & 600-Ohm) and the DT990 (250-Ohm & 600-Ohm), but never really use them.
Yes, no really good reason for buying high impedance headphones (unless they are the 300-Ohm HD600/HD650/HD6XX).So I have to spend $100 extra just for a good experience? xD
Should I instead just go for something that's lower impedance?
