Thank you very much, definitely something to look into!
I suppose you disable all VSS on the 7.1 device then.
You’re welcome and yes.
Or my AVR receiver over HDMI, that one gets detected as 7.1 as well.
So if I take that one, configure it as 7.1, apply the Waves NX effect for headphones and listen to the phones out of the receiver.
Would that work?
Probably. Can’t imagine why not. There’s a free trial so you can try before you buy.
I just started playing with Boom3D and liking it more then WavesNX maybe because i have no way to use it with the head tracker and my desktop inboard sound card is pretty crappy but it doesnt support 5.1 / 7.1. Plus for me the presets seems to have a lot of reverb with my dt 990's.
I was thinking of getting the sxfi amp which was mentioned but for some reason i cannot get it on creative website, amazon or newegg here in canada same goes for the sxfi theater and i hear the headphones haven't gotten the sxfi gen2 yet.
I really want the Mobius but i am having a hard time to justify the price since i game on PC and Console and while i was thinking of getting the Platinum headset is it worth it now that PS5 will be coming out.
The G6 would probably be the best for me, but again i am probably over thinking it but i have a hard time paying 250CDN for something 2+ years old and my opinion sxfi would probably be the future.
If you get the G6, you would also be able to use it for Waves with webcam or headtracker, Boom, Atmos headphone etc. on PC and probably apply any software VSS offered by the next gen consoles (assuming Sony allow the PS5’s proprietary native VSS to be pushed to external third party devices) which is particularly useful because it’s just a very good gaming dac/amp for the price in general. You can also push audio, EQ and FX out to speakers or another Dac/amp like your Syba Sonic if you so choose.
I use the G6 for Waves, Atmos for headphone and Boom 3D on the PC and Atmos for headphone on the Xbox One.
Re Mobius and SXFI future proofing
It’s just speculation at this point but I have a feeling that the next gen consoles will support discrete multichannel PCM output via USB just like PC does at the moment. If this does happen then there’s a good chance that Mobius / Orbit and SXFI devices will be updated for full compatibility so getting a Mobius or SXFI device may not rule out full console compatibility in the future.
Platinum Wireless and cheap alternative option for PS4 VSS dac/amp - Earforce DSS2
The Platinum Wireless doubles as a good wireless headset for PC although the VSS is limited to PS4 only. It’s also relatively inexpensive.
I’d say the Platinum’s worth it as a temporary PS solution but if you want to go the SXFI or Mobius route now and just want something to tidy you over on PS P4 for ultra cheap, then if your Beyer’s are the 32ohm model (which I have heard are easy to drive) then you could just get the Earforce DSS2.
It can be found new for around 20 bucks if you shop around, supports Dolby digital 5.1 decoding via optical in and is the only gaming dac/amp I know of that offers configuration of the virtual surround speaker positions (you can choose from multiple presets). Additionally it’s very small and light. I got one recently for 20 and was very impressed. It’s a bit reverby but not that much more than SXFI.
In any case, I think we have reached the limit of recommendation and conjecture, where you go from here is best determined by you trying/buying, forming your own hands-on impressions and return/refunding as necessary until you are happy.
Good luck!
