mbyrnes
Is it bad I have no idea what this game is? Lol
Has anyone tried running the K7XXs with only the mixamp? I'm wondering if an amp is needed if they're only used for gaming.
That's a shame. I don't know if it's worth buying an amp because I wouldn't be able to use it with my laptop (they're pretty far away from each other). I don't listen to music that much but I still don't know if I can justify the cost in that case.
Really, I'm just trying to find something that has some of the fun that the X2s have, but with roomier pads and less clamp. I've stretched them as far as they'll go but it's still not very comfortable; especially on the top of my head. I have the same issue with the X00's headband and pads so maybe I just have a big head/ears. but it's very frustrating trying to find a headphone that I can actually consider comfortable and fits my preferences. I might just buy a K7XX to see if the comfort is right, and look into an amp if everything checks out. If not I could always sell it.
If You're after a gaming only pair of cans try the PC37X. It's relatively cheap and very potent.
He'll have to stretch them out, to reduce clamp though. He should be doing that with the X2 as well. Clamp is something easily remedied on everythihng but the cheapest, easily broken headphones.
As a non-audiophile listener, would upgrading from a DT880 250ohm to a 600OHM have any noticeable upgrade in terms of sound, assuming I had a powerful enough AMP to power them? (Not sure if double amping the Astro mix amp and Fio E-12 would be enough) I love the DT880 250ohm, but just wondered if the 600 ohm would yield any noticeable differences. While on this subject, My DT880 250 ohm are a used pair and sometimes when I use my mix amp and fio E12 together I’m hearing distortion in some video game sounds when it comes to some explosion sounds on PS4 and wondered if I have a bad pair of headphones or if I am using the amps wrong. I usually set the mix amp to almost all the way up, to maybe in between 2 and 3 o clock (with 3 o clock being all the way up) and use the Fio amp to raise and lower the sound.)
Also, I have been reading different reviews and some people say the DT770 has more bass than the DT880 and vice versa. Anyone have an opinion on the bass differences from someone who has used both? Is this a matter of opinion per person? I know one is a closed can and one is “semi open”, so maybe the bass sounds different between the 2? I have heard DT770 blow your ear drums out, but then I have heard the DT880 and 990 have more bass and the bass certainly doesn’t blow my ears out in my 880 250ohm or the 990s I had previously. Thoughts?
I have a astro a40tr with mixamp pro tr and looking for a upgrade. Is the Fidelio X2 worth 237$? Should I buy a new amp or the current one is good enough with the X2?
Thanks for the reply! You know. I loved the DT990 pro 250 ohm EXCEPT for the mids? I love rock music and videogames but the vocals in songs and games always were too quiet and music and sound seemed to really over power them. I dont think a headphone exists that im looking for. unless there is a DT990 with louder vocals ha. And I will play around with my mixamp (I have the older version with the white slanted stripes under the voice chat knob.I don't think you stand to gain much from a 250 ohm to 600 ohm swap, unless you were trying to match to a certain OTL amp, and even then that is probably going to be minimum. If you were looking to change up your sound, give us an idea of what you like about the 880 and where you are looking to improve it. Budget also helps a lot. The reviews in the front of this review basically cover the different ohm models for the DT990 I am positive, and possibly the DT880, DT770. MLE did an awesome job with the first page reviews.
I wish I could comment more on the Mixamp and where to dial it in. If I remember correctly, I didn't use mine at full out, to avoid distortion. Try maybe 2/3 on the volume of the Mixamp and control the volume how you have been. Trying the Mixamp at different output levels may yield very different levels of distortion. Each Mixamp revision has had its weirdness about different functions. Mine is a 2011 I believe.
Pretty sure the X2 doesn't really need extra amping. I've never heard it, but it is low ohm and efficient. Should be able to run off of a phone. Double amping never hurts and may bring more out of the X2.
