chicolom
- May 3, 2008
Eric_C said:
Telltale said:
It works good. It is SUPER sensitive. You just bend it around and the placement isn't that crucial because of the high sensitivity. Just a couple inches away from your mouth is fine.
I love that I can just unsnap the magnet when I'm done and I get my headphones back again, without any "mods" hanging off it. That's what sold me on it.
I have some CALs here. I can test them again with gaming if you want...
Yes, that would be great if you could test them!
They're just OK. I wouldn't get them specifically for gaming. They're a little to bass heavy and warm for my tastes. The positioning is alright. I'm used to open headphones, so the soundstage seems small but for closed they're decent. Better than the JVC RX900 I used to have. They're excellent for music though for the price.
I would say aim for an open pair, unless you need closed specifically. As far as closed headphones in the price range, the CALs are one of the better choices.
Thanks for testing. Did you find them to be veiled at all?
Sweet. I just ordered one, it should get to me by mid-Feb. I kind of need a new mic to game on Xbox now--I just bought a Razer Onza, and it doesn't accommodate the old, official Xbox headset puck, plus the newer headsets that MS was packaging with consoles isn't available in my country. Oh well.
Best of luck on the Onza mine lasted 3 months and the right stick lost calibration and it was always moving on it's own accord. My brothers also lost his calibration but was able to get it back after several resets. I could never get mine to work again. Both were tournament editions so that might make a difference. I really loved it while it worked. There was a huge thread on the MLG forums full of complaints.
I forgot about this thing http://www.madcatz.com/mlg/360_controller.htm
Too bad its $100
I realize that buying two headphones would be an obvious solution, but I would really prefer not to do that. What is the best pair of headphones I could get from bestbuy.com that would satisfy the above criteria? My budget is under $200. Thanks for any suggestions.
