- Mar 20, 2010
If you're not going to use virtual surround, just get the Schiit stack. Better internals, power, etc.
As good as Schiit is, I'd advise to go with Audio-gd at the $300 price range. You get way more bang for buck, just no rca input (which in his situation he won't need anyway).
Yeah that was my initial thought.
Yeah i dont really need rca but i havent really looked into audio-gd what model do you suggest because i dont evven know where to start.
Just get a Boompro and a compatible headphone to plug and play on the mixamp. HD598? X2? SHP9500?
I personally now use the SHP9500.
If I've already got the HD558 it wouldn't really be worth it to upgrade to the HD598, would it? What's the next step up from there? HD600 or HD650?
If so, then I'll also need a dac/amp too?
NFB 11. The 15 (what I have) would have been another option but it's now discontinued.
Just picked up the Mixamp Pro TR and have been using that with my Sennheiser HD558 headphones for a little while now on Xbox One... Just picked up the new A40 TR headset yesterday to see if it's any better than the old A40's that I used like 4 years ago on the Xbox 360. Maybe it's just me, but the headset just seems terrible. Compared to the HD558's it just seems like all the sound is muffled and like there's too much bass. It also seems significantly underpowered compared to the HD558s. The same volume (~60% on the mixamp) produces near ear-splitting sound and I've basically got the max out the sound dial for the A40's and still seems lacking.
Should I just return the A40's or am do I have a bad headset? Anyone else have A40 TR + Mixamp Pro TR and have any similar experience?
I wanted a more complete headset instead of just headphones, which is the only reason I even purchased it. That and I already had the mixamp. I just recently remembered this guide and kinda wish I had reviewed this again before buying anything, but alas...
Addendum: I feel its worth noting that I'm a relative newb when it comes to audio, I just want to get the best experience I can for FPS console gaming. I've also got a pair of ATH M50X that I've got at work for listening to music, don't know why I haven't brought them home to try for gaming yet.
My point is, no headphone will be much of an audio upgrade if gaming on console with a mixamp. The whole point of console gaming is simplicity (right?), which is what I was suggesting. Does your HD558 have a 3.5mm input?
Edit: never mind, scratch the 558/598. What you will want for a more headset-like feel for FPS console gaming is something like the Philips X1, X2, or SHP9500, with a Vmoda Boompro mic. That will basically be just plug and play with your mixamp, with some slight workarounds on XBox in regards to plugging something into the controller (which I'm sure you are already used to).
