Rebel975
- Jul 3, 2010
I apologize if this is a stupid question. But if I use the wireless mixamp, will the PC 360 be powered by the mixamps batteries?
Yes, they will be.
The wired mixamp can run off usb power instead of batteries, same as the wired mixamp. Wired mixamp is most likely called "Pro" because its the one MLG uses; wireless mixamps all over the place would be an interference nightmare.
I will be using a wireless mixamp as MLE has stated there is no noticeable difference in SQ between wired and wireless. Plus, I play in my living room. And my TV is not feasibility near me to run a wired mixamp all the way to my couch. It would be too messy.
I still absolutely recommend the PC360. It's incredibly solid and well balanced for all forms of gaming. It's not going to jump out and grab you in terms of dynamics, but it won't lack in anything really. It's just a very great performer, and should honestly be what people should consider as their headset.
New headsets have arrived, like the Tritton Warhead and Turtle Beach Deltas, but I haven't had the chance to try those, nor do I want to. I'm completely satisfied with the PC360+Mixamp combo. For anything else, that's what non-gaming headphones are for.
Thanks for replying so fast, really appreciate it!
Ok, I made my choice and I'm going to order a PC360. But what exactly does the 'Astro MixAmp USB 7.1 Surround' do? Does it do the same as a dedicated soundcard? Because a mixamp is quite expensive and hard to get (I'm talking about Belgium right now), while a dedicated soundcard only costs half as much (the Asus Xonar D1 for example).
Or am I now mixing up two different pieces of hardware?
If you're gaming on consoles then get the mixamp, if you're gaming on the pc get a good sound card. If you use the mixamp on the pc using the usb it just works as a stereo amp, you dont get use of any of it's features.
So you're looking for headphones other than the ones mentioned in the original updated thread to consider, is that right? Might I ask why? What are you looking to get out of these headphones/Headset? What uses aside from gaming would you be looking to get out of them?
