Rich887
- Aug 20, 2012
Hey MLE ... just because its eating me are you saying the TH900 do have a larger soundstage closer to the Annies Etc ?
They do, but it only works with a PC as a source (meaning no consoles).
Thats what I was looking for... a sound card to be used as DAC (no amplification, but with Dolby HP encoded) and connect to headphone amp... there is really no option here?
Anyone with the BoomPros have a problem with it spinning out of position? I'm waiting for mine along with my X2, and I'm curious. Since it's a regular 3.5mm plug, there doesn't seem to be anything keeping it from spinning all over the place.
I've never had an issue with the boom mic turning away from where I place it. It's held in place by pressure and friction inside the jack.
Yeah, the new cable runs at .6 ohms for me, and it has no issues. I do hear a fair bit of complaints about other people's cables though, so i suggest you having an alternative just in case.
Victor, the Asus Xonar U3 is a cheap external soundcard with the ability to send dolby headphone DIGITALLY to your own dac (it needs an optical input, like the Fiio E17), and then your own dac to your own amp. The U3 isnt great if youbuse it alone, but as a digital source of Dolby Headphone, it's as good as anything else, as you're not limited by its own technicalities.
Apparently there are alternatives with other virtual surround, but I dont know which.
