Then that has nothing to do with the headphone amp section, but something to do with the chat capability. So many factors that can cause problems there, all which I'm not well versed in.
I ws just referring to the Mixamp alone vs double amped hiss, which people seem to think has more with an attached amp. I'm here to say that there isn't 'more' if you were to have the same exact volume level. Double amping has more hiss simply because you're pushing the volume higher than the volume alone on the Mixamp, so of course there is gonna be more hiss. The hiss is embedded into the signal once it reaches the Mixamp. Lowering the volume on the Mixamp isn't going to reduce hiss to your other amp. In essence, you're just killing bit resolution and making audio quality worse. (though I'm not clear on this, as double amping is usually taboo in the headphone world). I'd like to know how lowering the first amp's volume differs from lowering software volume. I may be completely wrong there and lowering the first amp's volume may not be detrimental to SQ.
Pretty sure, as long as the first amp sends out at LEAST a line level signal to the second amp, you're good. Problem is, what is line level from an amped signal, i.e. from the Mixamp? 20% volume, 50%, 100%? Just don't know. Just, a line level from a dac is very quiet, but if line level was AMPED, the loudness from line level has changed once it hits the (mix)AMP. These are things that I desperately need answered.
In any case, it's been awhile since I've tested the hiss between the two, but I'm pretty convinced that hiss remains at the same amount of loudness per decibel with or without an attached amp, as long as the attached amp doesn't add it's own hiss.
I prefer to err on the side of caution and keep my volume closer to max out of the Mixamp to ensure I'm sending out as much bit data as possible to the next amp.
