Perfect, you're just whom I've been looking for
Following the ratings from the first page, how would you rate the K702 65th and the PC37X:
Fun:
Competitive:
Comfort:
Thanks
I'll do my best!
PC37X:
Fun: 8.5. lots of mid bass which is the range that sounds like bass to most people. Doesn't extend deep. Explosions and other bass sounds are present, helping immersion.
Competitive: 8.0-8.5. above average for sound stage, footsteps are clear, high frequencies are there, although slightly rolled off. Are not fatiguing after long sessions.
Comfort: 7.5-8.0. these fit my head well, are on the smaller side for a full sized headphone. Ear pads are comfortable for long sessions. Some may have less luck with large heads or ears. I personally have no issue after hours of wear.
AKG K702 65th/K7XX/K712 (these are all very familiar sounding, K7XX I expect is slightly less, as good as the others).
Fun: 7.5- bass does extend deep, but bass feels about 3dB down overall. It's clear, detailed, but you won't feel explosions like better cans in this department.
Competitive: 9.0- these are still one of the best I've ever heard for soundstage in gaming. These are very good at hearing footsteps, and directionality. They're relatively flat sounding, with a slight mid bass bump. Very open sounding, which helps with range detection.
Comfort: 9.5. I really like the suspension system they use, and the flat headband (no bumps) of the 65th anniversary really float on my head with little clamping force on my ears. The bumps drop comfort a good bit (sooooooooo many versions of the K series). The large ear cups do not touch my ears, (65th Annie's are angled). Overall, a light headphone, which is great for long listening periods.
Now these are my opinions, and the numbers aren't based on price. IMO cost shouldn't factor into the numbers.
Clarity is not a factor in these numbers. Something like my Hifiman HE-X V2 is Crystal clear, but you'd expect that from a $1,300 planar headphone. Spending more on headphones for gaming, usually results in clarity and detail retrieval far better than sub $400-$500 options. Honestly you don't know what you're missing until you step up into the TOTL type Headphones. Ignorance is bliss in this case. Many of the expensive headphones are heavy, where these 2 are definitely much lighter than my more expensive cans.
I prefer the PC37X for casual music listening. I do prefer a V shaped sound signature for music. Both are very good with surround gaming. One is better at competition and the other is more done while still being competitive.
