mbyrnes
Hell of a long thread!
I have a Reasliser on order to use for movies and gaming.
I will need to use closed headphones to keep the sound from leaking too much.
They don't need to be super-isolating with no sound leaking at all but they can't be as loud for my environment as open headphones as well.
For that matter any closed headphones will do.
I am considering a top pair of closed cans as I want to use them for music as well.
But most important is a big soundsatge/positioning of course as surround sound through the Reasliser will be the main use for these phones.
So what would be the best closed phones for surround with good positioning?
Some phones I have or am considering are: Sony MDR-Z1R, Denon AH-D7200, Fostex TH-900, Pioneer SE-Monitor5 and ZMF Eikon.
Any advice?
Well a few of the headphones you have listed aren't closed. The Denon, Fostex, and ZMF are all semi-closed, and they will leak sound. I have the Fostex TH-X00 Ebony and they leak sound pretty bad IMO. This headphone is VERY similar to the Denon and Fostex, as they are all essentially cousins of each other with very similar designs.
If I was looking for a closed headphone right now, I would buy the Mr. Speakers Aeon ($799). They have a lot of the tech that is in the Ether C and Ether C Flow, and cost WAY less. Currently the Aeon is on the Wall of Fame at Innerfidelity, knocking the Ethers off the wall of fame. It would require an amp to get the most out of them, which the Realizer should provide with it's internal, powerful amp. Another I would look at is the Audeze LCD-XC ($1799). I have not heard either of the two, but these are probably the best, actual closed, headphones on the market. There is also the Beyerdynamic DT1770 ($599), but I don't think these will compete with the Aeon for $200 more.
On a side note, While I use open or semi-open headphones, I think soundstage size is dramatically over stated here at Head-Fi. There are a few designs which truly sound huge, like the Sennheiser HD800/HD800S, Hifiman HE-1000, etc. My Hifiman HE-X have a huge soundstage compared to most designs I have heard. For gaming and movies though, the differences to me are subtle at best. I don't feel like I am missing all that much if I use my Fostex or Monoprice M1060s instead. There is a difference, but very few games IMO take advantage with their sound design, and virtual surround does a good job of simulating a large soundstage. Also realize that the A16 you are getting should be able to make a closed headphone sound more open. I personally would grab the Aeon, save yourself a grand, and enjoy a very well made headphone.
I wish you the best of luck, as closed back headphones just aren't as common as open or semi-open. There are literally a handful of TOTL headphones that are closed. Most reviews talk about sound leakage, so you can get an idea of how bad each headphone is. IMO most semi-open designs leak almost as bad as a fully open design.
