SpiderNhan
how do the m80's compare to the audio technica m50s, I've heard good things on the too?
http://www.head-fi.org/t/588813/ath-m50-v-hd-25-1-ii-v-v-moda-m-80-v-srh940-help-please
Should answer all your questions.
Hey what are the best headphones for around 150- 200 dollars, I listen to the all kinds of music so just the best overall headphones I can get
can someone recommend some headphones that will fit my small head?
my budget is 150$ and i listen to hardstyle/house/electro
thanks
I sent my PRO700MK2's back, the sound and bass was pretty good but the clamp was too much for that price. I found myself constantly adjusting the cups trying to find relief especially after listening to my XB500's...they just felt like hell.
I just ordered the Ultrasone Pro 550 but they are on back order so I'll won't get a chance to listen for a while.
http://www.bhphotovideo.com/c/product/568387-REG/Ultrasone_PRO_550_PRO_550_Closed_Back_Professional.html
^^^best price that I found.
^ I find it amusing people send their headphones back because of clamping when you can easily fix that. Overnight streching over some suitable wide object is your friend. My AKG K518 DJ went from 15~20 mins wearable tops until intense pain in the ears started to develop to at least 1½ ~ 2 hrs wearable from 2 overnight streching sessions.
Welp, here I am. Been lurking here for months and decided I should chime in and ask for some help. My beloved Koss PortaPros are finally breaking down after much, much use and I am looking to replace them with a good step up. These will be my first "real" pair of headphones.
I will mostly be listening to music while walking around, so a fully portable or light design is preferred, though I will easily drop that requirement for better sound. My biggest requirement is that they headphones cannot be THAT big. There is only so much portability that I can sacrifice, you know? My current budget is preferably ~$100, though I can stretch it to ~$150-$160 if I have a good reason. I listen to primarily Rock/Metal music, with a bit of electronic rock and techno mixed in.
Yes, some of these are well above my budget. However, there is currently a nice sale on many headphones/earbuds on Amazon, and I would like to take advantage of that.
I have been looking at the Grado SR80is, Shure SRH440s, and AKG K-240, Audio Technica ATH-A700, Audio Technica ATH-AD700 for ones that fit my price range fairly well. I have also been looking at the Audio-Technica ATH-M50 for one to stretch my budget, and I have been hearing very mixed reviews about the V-Moda M-80. Some swear it is the best looking, best sounding most comfortable thing they ever worn, others say that it is completely junk.
Sadly, I am unable to try some headphones before I buy them; there isn't anywhere near my that even sells higher end headphones, and I do NOT appreciate that.
I should also mention that I can buy a portable amp separately if anyone has recommendations for one for a particular headphone. I have never used one before and am at a complete loss with them
I have deep, deep reserves about other on-ear style headphones, such as the Grados. I had good luck with the Koss PortaPros, but I still don't understand on-ear headphones. I still prefer closed-ear whenever possible, for comfort, sound quality and isolation.
Any help, advice, and other recommendations welcome! Cheers, and thanks in advance.
